Idle problem on start up with b16a2
Old Jan 23, 2003 | 04:36 PM
blazinb16's Avatar
Default Idle problem on start up with b16a2
I just recently swaped a b16a2 into my cx i was forced to use a p72 with the motor because the ecu street imports sent me was junk..the car runs fine but when i first start it in the morning it revs and idles like it would eny cold morning but only for a few seconds at witch point it slowly dies..i can give it gas very gradualy but to much gas and it will die. When i can get it to rev it sounds as though it's running on only a few cylinders....it dose this untill the car is warmed up...eny ideas on what this could be? thanks
Old Jan 24, 2003 | 05:19 AM
blazinb16's Avatar
Default Re: Idle problem on start up with b16a2 (blazinb16)
enybody?...little help here
Old Jan 24, 2003 | 05:31 AM
Drews Bitch's Avatar
did you check the plugs?
how's the commpression?
fuel pressure?
any vacum leaks?
good luck
allmotorb20R
Mar 4, 2019 07:04 PM
RiTtEk401
Nov 28, 2011 12:43 PM
civicef990
Nov 21, 2011 04:14 PM
kim_2_da_chee
Mar 2, 2005 12:02 AM
