IAT Sensor Question
Old Jan 1, 2004 | 02:15 AM
FredoSP's Avatar
Default IAT Sensor Question
Real simple question ...
I just picked up a JG Intake manifold for my 00 Civic Si, B16A2, OBD2.
The IAT sensor that came with the car goes in the intake piping. I wanted to relocate the IAT to the intake manifold, seen that the JG has a spot for it. I already ordered an OBD2 IAT from the Acura Dealer.
My question is this: Is it a plug and play? Meaning I can take the new GSR IAT sensor and plug it into my existing wiring harness or do I have to cut and splice certain wires?
Thanks in advance
- Fred
Old Jan 1, 2004 | 08:12 AM
Mikey3000's Avatar
Default Re: IAT Sensor Question (FredoSP)
all Honda/Acura IAT sensors are the same as long as they are both OBD1 or OBD2. so, yes its just plug and play. why did you order another sensor?
Old Jan 1, 2004 | 01:52 PM
FredoSP's Avatar
Default Re: IAT Sensor Question (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">all Honda/Acura IAT sensors are the same as long as they are both OBD1 or OBD2. so, yes its just plug and play. why did you order another sensor?</TD></TR></TABLE>
B/C the JG has the spot for the sensor on the intake manifold, which in my opinion will give a more accurate reading of the air temperature (after being intercooled) versus having the IAT in the intake filter/piping of the turbo before the intercooler.
Does this make sense?
Old Jan 1, 2004 | 02:44 PM
Mikey3000's Avatar
yeah that makes sense, i was wondering why you had to buy a new one? was there something wrong with the one off the SI?
Old Jan 1, 2004 | 09:17 PM
FredoSP's Avatar
cause they are two different shaped sensors
Old Jan 2, 2004 | 04:39 AM
VTECVillain's Avatar
That's not true. The 96-98 Civic's have the IAT mounted in the intake pipe and the engine harness plug and sensor are shaped different (more squared) than the typical round IAT found on the OBD0/OBD1 Civic's and all Integra's.
Old Jan 2, 2004 | 05:43 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">cause they are two different shaped sensors</TD></TR></TABLE>
ohhhhhhhhhhhhhhhhhhh. i guess it wont be plug and play then. maybe you'll have to get your hands on a GSR IAT connector and replace the stock one with it.
Old Jan 2, 2004 | 04:45 PM
GOLDBERG's Avatar
Does this make sense?</TD></TR></TABLE>
no it doesnt...the iat usually goes up on the intake pipeing near the throttle body..theair temp would be the same..it would be AFTER the intercooler..so no that doesnt make sense
Old Jan 2, 2004 | 06:51 PM
FredoSP's Avatar
Default Re: IAT Sensor Question (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
no it doesnt...the iat usually goes up on the intake pipeing near the throttle body..theair temp would be the same..it would be AFTER the intercooler..so no that doesnt make sense </TD></TR></TABLE>
Sorry your wrong, on the B16 Greddy kit the IAT senor WAS in the turbo's intake piping (PRE-INTERCOOLER), thus moving it to anywhere AFTER the IC would warrant a true intake temperature, post intercooler.
Old Jan 3, 2004 | 06:00 AM
GOLDBERG's Avatar
Sorry your wrong, on the B16 Greddy kit the IAT senor WAS in the turbo's intake piping (PRE-INTERCOOLER), thus moving it to anywhere AFTER the IC would warrant a true intake temperature, post intercooler.</TD></TR></TABLE>
so the b16's iat sensor u r saying..is on the exhaust manifold from the factory??thats a o2 sensor bud
but hey its cool man..my friend was lecturing me and saying that the iat in the intake pipe was an o2 sensor..so your in the same boat as him i guess..its koo
Old Jan 3, 2004 | 06:02 AM
GOLDBERG's Avatar
and goddamn u would have to extend wiring like a crap load if u r actually right..about the greddy kit placement anyways..but hey..u dont have a drill and a file at home to make a new iat sensor hole??or just...hopeless?
Old Jan 3, 2004 | 06:10 AM
FredoSP's Avatar
of course im right I just owned the damm thing. No need to be an ******* in your posts.
edit: Some Pics for thought
Old Jan 7, 2004 | 07:05 PM
GOLDBERG's Avatar
ive got that stupid hole with the sensor on the back of my jg..but the plug is different..i dont use it..leave it where it is
Old Jan 8, 2004 | 09:10 AM
MikeySpec's Avatar
Very slick!good job!I was in a rush to just get my integra running and i was in the same dilemna.So i shoved that sucker into a vacuum hose,started it up...it got rid of the code.And now i have a way to get to work!
tigueremalo
Nov 10, 2007 04:42 PM
EK8D15B
Sep 8, 2007 05:39 PM
bboylito
Mar 19, 2005 08:04 PM
spookhatch24
Dec 30, 2002 12:53 PM
