I dont have a check engine light!
well, i just got finished doing an obd0>obd1 conversion and now when i start my car i dont get the cel light that flashes with oil pressure light and seatbelt light. i took my car out and it is not running right. I tryed splicing into pin A13 with another led which, correct me if im wrong, is the cel. still no luck. then i thought it was the ecu so i swapped another ecu in and NOTHING!! im so frustrated, someone please help a brotha out!.
i am assuming that you have an ef right? If you do, and you have converted to obd1, try jumping the little plug in the engine bay. It is located by the driver's side motor mount, the wire harness that is running from the firewall to the headlights along where the fender bolts to the body. There is a little two pronged plug that connects to nothing. Try jumping that and see what happens. Good luck.
usdmEHboy
Feb 18, 2007 07:34 AM
Atreyu57
May 16, 2006 12:19 PM
