Hybrid engine question-
Old Jan 2, 2010 | 07:24 PM
darkenedsol's Avatar
Default Hybrid engine question-
Hey-
Have a B20 block with a 95 GSR cylinder head in my Del Sol Si, run by a 95 P72 GSR ecu, and my question is whether or not I can/should eliminate the knock sensor from the ecu since the block does not have a ready provision to have a knock sensor? Also, does anybody know whether or not a 95 GSR has a provision for an oil-pump mounted crankshaft position sensor or if I don't need it as the B20 I have has no holes in the oil pump to mount the sensor. Considering the above, would I be better running an actual GSR harness or simply adding to a P28 harness as those are easier to get??? Thanks for any help!!!!
Old Jan 6, 2010 | 09:22 AM
Default Re: Hybrid engine question-
bump
Old Jan 11, 2010 | 09:06 AM
bump
JdmCrx209
Feb 21, 2013 10:46 AM
konbeef
Feb 18, 2009 06:00 PM
hondaman1212
May 8, 2008 08:59 PM
CiviCVuE
Mar 13, 2007 06:00 PM
rtype11
Nov 9, 2001 10:05 AM
