how to tell the difference
Old Jun 16, 2007 | 01:56 PM
BoogiepopJDM's Avatar
Default how to tell the difference
how can you tell the difference between 94-+ b18b1 obd1 and obd2? (besides the intake manifold) and the b18b1 that come in the DA from 91-93? and what are the differences between the obd1 and obd2 as far as sensors on the block and such?
Old Jun 16, 2007 | 02:02 PM
oneslowstd's Avatar
Default Re: how to tell the difference (BoogiepopJDM)
Well as far as sensors, I believe the 02 sensors are four wire on obd1, dizzy wires are different, and injectors maybe, but in any case you will normally use the harness off of your car in any swap. As for the DA question, they were B18A1's and I believe the 92-93 were mostly obd1! Oh and obd1 usally don't have resistor box's but that all matters on impediance.
Old Jun 16, 2007 | 02:51 PM
ok i am planning on swapping a b18b1 motor using my stock harness whether its obd1 or obd2 with an obd1 mani and dizzy. is there anything i should know if swapping a b18b1 obd2 motor in an obd1 eg besides using the obd1 mani and dizzy
jlowellintegra
Sep 3, 2010 07:34 AM
JJGL-EF90
Feb 17, 2010 08:07 AM
integranator
Jan 23, 2008 10:03 AM
crazyfiz
Jul 6, 2006 02:11 PM
Pompiuses
Jun 29, 2006 07:18 AM
