View Poll Results: Install the engine from the top or from underneath?
I drop the engine from the top.
69.81%
I raise the car and install the motor from the bottom.
30.19%
Voters: 318. You may not vote on this poll
How do you "drop in" an engine?
Old Jan 1, 2009 | 03:51 PM
  #26
nix94delsol's Avatar
Default Re: How do you "drop in" an engine?
we have a hydro lift at the house =P drop the car on the motor FTW
Old Jan 2, 2009 | 09:44 AM
  #27
batboyvaj's Avatar
how do you guys swap it from the bottom without a hoist?
Old Jan 2, 2009 | 11:10 AM
  #28
Evs-One's Avatar
Solbros Owns Me
If you are using a hoist from the top, get yourself an engine leveler. Will save your paint and make life MUCh easier
Old Jan 2, 2009 | 05:32 PM
  #29
EGhatch87's Avatar
^^very ture..
Old Jan 2, 2009 | 05:57 PM
  #30
stealth50k's Avatar
i recommend getting longer chains on the leveler than that. Some levelers have small chains that end up scratching the valve cover.
Old Jan 2, 2009 | 06:00 PM
  #31
NVturbo's Avatar
O.G. triple O.G.
On Hondas, I don't have a problem dropping from the top. As for others, I helped a buddy replacing his K24 (Nissan 240sx) and it's a PITA because you have to be careful not to bust the hardlines located at the firewall.
Old Jan 6, 2009 | 12:07 PM
  #32
kulo's Avatar
to drop a b18c1 into an ek
from underneath
do u need to remove all mounts
bolt rear t bracket to block?
Old Jan 8, 2009 | 06:14 AM
  #33
JDM JEFFREY's Avatar
from the top with lots of care I have a shaved bay
done it from underneath too..what ever works
Old Jan 9, 2009 | 11:18 PM
  #34
MR.johnson's Avatar
Originally Posted by stealth50k
From the top. I always try to hook it up to the block and tranny because one time i hooked up one end to the head and it caused a head gasket leak. The heaviness of the engine made the bolts stretch.
i sure hope your joking.
Old Jan 10, 2009 | 07:29 PM
  #35
slowcivic e g's Avatar
I've done probably 7 from the top and 1 from the bottom. I like going from the top.
Old Jan 18, 2009 | 12:31 AM
  #36
fergs96integra's Avatar
Well depends on the install usually its from the top but when its easier from the bottom and i have the lift free i do it from the bottom. Removing an engine or installing one, i have done it all ways and it all depends on what i am working with.
To the guy above asking how to do it from the bottom with out a hoist.......
its a little harder to do but you have to do what you have to do. Any ways to remove the engine, i took the wheels off and lowered the car as far as i could with a dolly under the motor then i disconnected everything and then lifted the car as high as i could with the car jack, propping it up with blocks and such to get it up high enough to clear the engine. Then did the reverse to put the knew motor in. That was a brief explanation for you if that helped any.
Old Jan 19, 2009 | 09:17 AM
  #37
Tyounin608's Avatar
I've always dropped them in from the top.
I'm thinking about switching it up one of these times just to see what it's like.
I used the same tactic to con my ladyfriend into buttsecks, lol
Old Feb 24, 2009 | 01:34 PM
  #38
American.Graffiti's Avatar
Ive done one through the bottom but would prefer to do it with a hoist above though.
Old Feb 24, 2009 | 05:06 PM
  #39
unusual71's Avatar
out the bottom is definitely the junkyard way. when i pulled my LS out of the donor car we dropped it out the bottom, but putting the motor into my civic I will probably put it in from the top, i didn't really like doing it out the bottom.
Old Feb 25, 2009 | 06:34 PM
  #40
stunn'd's Avatar
My only word of advice: If your working topside with a hoist/cherrypicker, Watch out for the TPS Sensor! They are your worst enemy.
Old Feb 26, 2009 | 09:53 AM
  #41
getnasty's Avatar
I have broke prolly 5-6 of them bastards! I have become a pro at getting those rivits out know!! lol
Old Feb 27, 2009 | 09:37 AM
  #42
MassScene's Avatar
Threw the TOP is the worst way known to man....in or out its such an uneccasary pain in the ***.....OUT from the BOTTOM in threw the BOTTOM...2 FLOOR JACKS 1 on each side and a nice Dolly does the trick....cleanest simplest way !
Old Feb 27, 2009 | 09:55 AM
  #43
kulo's Avatar
whats the best way to drop a gsr motor in EK?
top with a hoist
or under neath with car on ramp?
Old Feb 27, 2009 | 10:24 AM
  #44
hayabusa160's Avatar
slide the motor under the car, lower the car. use engine hoist to pull the motor up from under. thats what i usually do. never broke any sensors doing it this way.
dropping the motor from above is a pain in the ***. and you usuaully end up scratching up the engine bay.
Old Feb 27, 2009 | 06:56 PM
  #45
MassScene's Avatar
top with a hoist
No Need for Ramps @ all.....2 Floor jacks 1 on each side directly underneath the mirrors slide motor out + in on a Dolly so when you lower the car the motors already up high enough and you lower the car to the designated height.....ive done a swap in all EF/DC/EK/EG THE BOTTOM IS THE BEST/EASIEST ! Whether its a B-Series / K-Series dont matter...actually the K is even easier !
Old Mar 1, 2009 | 11:07 AM
  #46
kulo's Avatar
any pics?
Old Mar 3, 2009 | 03:37 PM
  #47
kingcu90's Avatar
good thing i have old school cherry pick its ment to pull diesel engines, and have two friends to guide the motor perfectly in as i lowering it....from the to of course..
Old Mar 3, 2009 | 04:04 PM
  #48
projectTeG's Avatar
ive always done my swaps from the top, never tried from the bottom, ill try that next swap.
Old May 31, 2009 | 05:01 AM
  #49
TheWraith's Avatar
Ive personally done maybe 5 or 6 motor swaps, Ive always dropped it from the bottom and in wither the backyard or the driveway. I have done it from the top with a engine lift but to me its easier from the bottom. Everyone has there own opinion.
Old Jun 1, 2009 | 01:45 PM
  #50
skar1's Avatar
So how would u guys recommend installin an h2b swap in an eg? From the top or bottom?
