help w/ ls/vtec
Old Oct 23, 2001 | 07:06 PM
98 Ek LsVtec's Avatar
Banned
Default help w/ ls/vtec
ok i was also most finished putting it together when i ran into some prob
1st prob i read somehwere that i should run a gs-r water and oil pump(i got a gs-r head)but i had bought a ls timing belt do i got to buy a gs-r timing belt ?
2 i also bought a after market block girdle and the ls oil ccatch or fedder whatver its called don't bolt right up do i have to buy a gs-r one?
thank alot
Old Oct 23, 2001 | 09:39 PM
rainforest's Avatar
Default Re: help w/ ls/vtec (98 Ek LsVtec)
yeah you need a gsr timing belt.
Old Oct 24, 2001 | 04:07 AM
Davep's Avatar
1.The timing belt depends on what water pump you use. If you use the b16/18c pump use the gsr belt, if you have the b18a/b pump use the b18a/b belt. The oil pump is nice to have but not essential.
2. If you have the z10 girdle you need the gsr main bolts, windage tray, and the oil pickup.
[Modified by Davep, 8:14 AM 10/24/2001]
Old Oct 25, 2001 | 05:53 PM
Banned
Default Re: help w/ ls/vtec (Davep)
thanks for the info.
B18 CYA
May 11, 2005 03:11 PM
GEN2INTEG619
Mar 24, 2005 08:39 PM
BoOsTiN Dc2
Feb 7, 2004 04:49 AM
BoOsTiN Dc2
Feb 7, 2004 02:32 AM
vtecb20coupe
Dec 10, 2003 12:15 PM
