help... jdm itr swap... bogging problems help
Old Jan 15, 2004 | 10:36 AM
jdmekcivic2eg's Avatar
Default help... jdm itr swap... bogging problems help
im having slight bogging problems. install a jdm itr swap in a friends car and it has a rough idle. no power at all when driving and it barely revs up at adle. shuts off.. and its no codes at all.... strange. any suggestion? thanks.. im using a vtec wiring harness basically a 96ex civic... and jdm itr ecu.. thanks
Old Jan 16, 2004 | 06:19 AM
Home Skillet's Avatar
Default Re: help... jdm itr swap... bogging problems help (jdmekcivic)
Is your timing properly set? Did you do a compression check? What's the condition of the motor?
Old Jan 16, 2004 | 09:18 AM
thanks man.. problem is solved! my boy is on the way back to nc... spark plug wires were on wrong..
Old Jan 16, 2004 | 09:26 AM
ouch, that'll do it. Glad to hear you're up and running.
EG Lifestyle
Oct 3, 2014 06:08 AM
EK [30-85]
Jan 9, 2006 09:18 PM
Civtegrar
Apr 24, 2005 01:59 PM
typegsr
Feb 4, 2003 10:19 AM
