Help.. JDM D15 VTEC in VX
Old Oct 5, 2004 | 12:23 PM
0bLiViOuS's Avatar
Default Help.. JDM D15 VTEC in VX
hey, i just dropped a JDM D15 vtec in my VX and the thing wont start... I'm using the P07 ECU right now (funds are tight) and it's not throwing out any codes, and there is fuel pressure and spark. I tried the P08 IM at first since it doesn't have EGR and all the VX emission crap, but I couldn't hook up the EGR stuff (obviously) so i thought that might have been a problem.. so i switched to the P07 IM and hook everything up, but still nothing. I have researched all I can, but not too much info on the swap i'm doing. If anyone has ideas lemmie know. I've check timing, connections, everything I could think of... just throw out ideas, i need this car running. oh.. and the car does turn over and begin to start.. I can hear it start for a sec, but then dies.
thanks
Old Oct 6, 2004 | 09:08 AM
0bLiViOuS's Avatar
Default Re: Help.. JDM D15 VTEC in VX (0bLiViOuS)
no one has any ideas? swapped ECU and got new plugs, so that's not a problem.. engine is starting for a sec but sounds likes it's drowning/sputtering and dies..
Old Oct 8, 2004 | 01:17 AM
Katman's Avatar
all grounds correctly grounded?
anything slightly unplugged? double check your plugs on the distributor etc...
got enough fuel?
battery dead?
Old Oct 8, 2004 | 09:25 PM
0bLiViOuS's Avatar
Default Re: Help.. JDM D15 VTEC in VX (Katman)
ya i know everything is ok.. but I took off the dist cap and found A LOT of oil in there.. so i'm guessing that's the prob so i'm going to get a new dizzy.. would the oil cause it not to start?
Old Oct 14, 2004 | 04:16 PM
Katman's Avatar
yes its possible.
You could have a layer of goop on the rotor or stators which isn't allowing spark to happen.
Spool This
38
Jun 12, 2008 06:24 PM
sammydigital
Jun 12, 2006 12:32 PM
HamiltonRex
Nov 28, 2005 09:53 PM
EGPHANTOM
19
Jun 3, 2005 11:50 AM
