Help! crx swap.
Old Dec 20, 2002 | 08:01 AM
RC_SKUBY's Avatar
Default Help! crx swap.
yeah i was wondering if a 1999 civic dx engine would go into my 1988 crx si? they are both d series so im thinking the mounts are the same, but the wiring is probably going to be the problem i think, does anyone have any advice? or at least a good web site to research this on? thanks.
Old Dec 21, 2002 | 05:33 AM
VTECVillain's Avatar
Default Re: Help! crx swap. (skuby_do)
Yes it will fit and is a cheap upgrade to a lower mileage motor. You need to change the driver's side mount and mount bracket on the 99 with the one from your CRX. After that it will drop in just like you're replacing the same motor. You can bolt your DPFI intake manifold onto the block, as well as the exhaust manifold and there will be no wiring headaches.
The only wiring change will be the coolant temp. sensor. On the CRX motor it is on the back of the block near your oil filter but on the 99 motor it is on the thermostat housing. All you need to do is cut off the plug, extend the wires to the length you need and then use a normal 2 prong plug.
For the best performance, I would recommend converting the car to MPFI and use 88-91 CRX/Civic Si components - distributor, ECU, intake manifold with injectors. I have an 89 Civic DX and swapped a 2000 LX (D16Y7) into it. I converted to MPFI and used all Si parts except the manifold, which I used one from a 95 EX.
Old Dec 21, 2002 | 03:34 PM
BudaKai's Avatar
Default Re: Help! crx swap. (VTECVillain)
What's even better is that you have more room for a bigger turbo and an air-liquid I/C. D-series do have their benefits.
Old Dec 26, 2002 | 08:40 PM
skud_dusty's Avatar
Default Re: Help! crx swap. (tzsir)
anthony, the swap is hella simple, i already told ya buddy
like vtec villian said, theres not much to it
but you already have mpfi, so dont worry about that
i-want-a-crx
13
Mar 11, 2008 03:55 AM
perseverance
Mar 3, 2007 03:26 AM
vtecdelly
Mar 4, 2004 05:02 AM
Elite Hatch
Nov 6, 2003 12:26 PM
JDM CRX
Apr 27, 2003 11:23 AM
