having some more problems. h23->sol
Old Jun 19, 2004 | 08:40 PM
rtpassini's Avatar
Default having some more problems. h23->sol
hey guys. i put an h23 into my sol. and i got it running decently smooth. so i took it for a test drive. when i gave it WOT throttle, it hesitated...i dont know if thats because the engine hasnt run in a while. but also. it would just stall. if i wasnt giving it gas. any ideas?
Old Jun 19, 2004 | 09:41 PM
Turbogixxer's Avatar
Default Re: having some more problems. h23->sol (rtpassini)
Check timing and vaccum leaks. You get the other things fix?
That swap just does not want to run right.
Old Jun 19, 2004 | 10:10 PM
rtpassini's Avatar
i know man. its like i find this problem. that i swear is going to fix it. but it doesnt.
the timing should be fine. and yes. i got the other things fixed....but
im still throwing the code for the IAC would this cause it? and also. i dont have the egr hooked up at all.
Old Jun 20, 2004 | 09:01 AM
Default Re: (rtpassini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtpassini &raquo;</TD></TR><TR><TD CLASS="quote">im still throwing the code for the IAC would this cause it?</TD></TR></TABLE>
Yes, it would make the car idle like **** and stall. You extend that connector at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtpassini &raquo;</TD></TR><TR><TD CLASS="quote"> i dont have the egr hooked up at all.</TD></TR></TABLE>
EGR will not effort idle at all.
Sk8ermane
Feb 25, 2008 02:10 PM
snowblind7x
May 25, 2006 09:19 PM
P95
Aug 20, 2005 02:52 PM
XxslayerxX
Jun 16, 2004 08:55 PM
HONDABOND
Nov 21, 2003 02:50 AM
