h2b 4.9 final drive??
Old Jan 17, 2011 | 08:15 PM
cloviskilla's Avatar
Default h2b 4.9 final drive??
watsup guys wondering if it would be wise to do a 4.9 final drive b16 trans with a mild h23bluetop setup?? would it be to low to utilize the torque?? ive been searching and cant find any info on it. i will be running 24.5 inch m@hs
Old Jan 17, 2011 | 08:38 PM
The Ogre's Avatar
Default Re: h2b 4.9 final drive??
Way to short, you have no RPM to make up for the mph lost id stay with a stock b16 trans if i were you, believe me my buddies h23 seems perfect with the b16 trans anything shorter would be ridiculous. Try out the zeal transmission calculator should help you out with what you want
Old Jan 17, 2011 | 09:37 PM
sounds like a plan.
Old Jan 17, 2011 | 10:08 PM
turbociv910's Avatar
for a road race car yeah
Old Jan 17, 2011 | 10:25 PM
that would be fun
Old Jan 18, 2011 | 03:45 AM
JayWest's Avatar
i think thats something you should look into AFTER you have the car dyno'd
you're going to want to see how your powerband looks and where your peak power is
i think with a 4.9, you're going to need to carry out the power a bit on an H
Old Jan 18, 2011 | 03:53 AM
soxle's Avatar
bigger is better, shorter is better. road race use, of course.
Old Jan 18, 2011 | 06:57 AM
thundernoodle's Avatar
I would think a 4.7 would be much friendlier street/strip wise
Old Jan 18, 2011 | 08:22 AM
SL0WEGG's Avatar
Would depend upon where you're making power and how much.
Old Jan 18, 2011 | 10:33 AM
The Ogre's Avatar
Is this going to be a dedicated track car? Just a daily to take to the track sometimes?
I say take it to the track on the stock b16 trans with the tires/suspension setup you plan to run and see where you exit the traps (what RPM) and you can choose from there.
Old Jan 18, 2011 | 04:16 PM
its going to be 90 percent drag strip 10 percent street. i live in small town no freeways here. i really think 4.7 will help at the track with 23 m@hs but hurt on the street cause of tire spin. but maybe im wrong...
chrisc543
Transmission & Drivetrain
Jun 10, 2013 12:47 AM
rrace002
17
Oct 28, 2012 12:21 AM
confusatron
May 30, 2006 12:50 PM
