H23 VTEC... SPECS...
Old Jun 9, 2006 | 08:11 AM
H23_Del Sol's Avatar
Default H23 VTEC... SPECS...
I need to find specs on my motor... this is all I could find which is really nothing LOL.... could anyone help me out...
http://www.jdmcustoms.com/h22a018.html that is the link of my motor
Old Jun 9, 2006 | 08:23 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: H23 VTEC... SPECS... (H23_Del Sol)
what else are you looking for?
Old Jun 9, 2006 | 08:57 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: H23 VTEC... SPECS... (2FAST4U831)
JDM H23A Vtec (blue top)
10.6-1 compression same as jdm H22A
It has a jdm h22a head on it
Has the same horsepower or even tad bit lower then the jdm h22a
refering it to my near stock jdm h22a 158 ft lbs of torque at 3200 rpm and I am sure it would be less then 5 ft lbs of torque difference
It wasn't enough of a power difference to get me to shell out the extra G
The jdm h22a has better power capibilites and you can take it to higher rpms and just the straight reliability.
Old Jun 9, 2006 | 09:47 AM
K-EG's Avatar
H23A VTEC
Accord Sir Wagon (CH9) (JDM)
197hp@6800/163tq@5300
notes: 10.6:1 CR, open deck likely regular JDM H22a head. 95mm stroke
Auto Tranny stock
http://english.auto.vl.ru/catalog/11619/
Old Jun 9, 2006 | 09:49 AM
K-EG's Avatar
H23 Del Sol this motor kicks *** if you dont already know.Dont listen to what anybody else says.This motor is by far better than a H22.
Old Jun 9, 2006 | 09:53 AM
K-EG's Avatar
Old Jun 9, 2006 | 10:47 AM
Very similar to my run.. i had 195 whp and 165 torque.....
Old Jun 9, 2006 | 11:42 AM
Adam.'s Avatar
Default Re: (H23aEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23aEG &raquo;</TD></TR><TR><TD CLASS="quote">H23 Del Sol this motor kicks *** if you dont already know.Dont listen to what anybody else says.This motor is by far better than a H22.</TD></TR></TABLE>
What's the difference? 95mm stroke, probably smaller bore. Same FRM sleeves?
Old Jun 9, 2006 | 05:56 PM
K-EG's Avatar
Default Re: (DarkKnight1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight1 &raquo;</TD></TR><TR><TD CLASS="quote">
What's the difference? 95mm stroke, probably smaller bore. Same FRM sleeves?</TD></TR></TABLE>
Acutally it has the same bore but bigger stroke.
Old Jun 14, 2006 | 09:59 PM
JDM MonopolyMan's Avatar
Subscribed. Finally a thread with info about the h23 vtec.
Old Jun 20, 2006 | 05:06 AM
Adam.'s Avatar
Acutally it has the same bore but bigger stroke.</TD></TR></TABLE>
So then what's the difference between this motor and a stroked h22? Nothing, so throw an H23 crank in an H22 and call it a day.
What the hell makes one motor so much better than the other?
Old Jun 20, 2006 | 08:05 AM
Banned.
the only difference I see is maybe better weights on the crank and good location of the squirters...
camden
10
Dec 21, 2011 07:29 AM
gurlie
Jan 2, 2009 07:19 PM
AnthonyG2003
Mar 29, 2006 05:08 AM
Nikoli
May 26, 2004 03:54 PM
WarpedSportzKid
Jun 10, 2003 07:18 AM
