H22a1 distributor
Old Jul 27, 2003 | 03:57 PM
Leisyman's Avatar
Default H22a1 distributor
Can someone tell me if there is a distributor from another engine which will fit JDM h22 motor? JDM has internal coil, but that is not a big deal, have run external MSD coil before.
JDM dist. is difficult to find, read $$$$, and am looking for less expensive substitute
Thanks
Ron
Old Jul 27, 2003 | 04:36 PM
Turbogixxer's Avatar
Default Re: H22a1 distributor (Leisyman)
any 92 - 95 dizzy will work.
Old Jul 27, 2003 | 04:55 PM
Leisyman's Avatar
Default Re: H22a1 distributor (turbogixxer)
h22 or other?
Old Jul 27, 2003 | 05:24 PM
sorry, dude, , civic, any 92 - 95 civic dizzy will work. Long day at work.
Old Jul 27, 2003 | 06:01 PM
Leisyman's Avatar
some are v-tech. come are not. are they actually all the same?
Old Jul 27, 2003 | 06:54 PM
Jonathan_ED3's Avatar
vtec
Old Jul 27, 2003 | 09:24 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leisyman &raquo;</TD></TR><TR><TD CLASS="quote">some are v-tech. come are not. are they actually all the same?</TD></TR></TABLE>
All of the 92-95 Civic distributors are same.... same internals that's also used in the JDM OBD-1 H22A distributors... just that they need to be modified to fit onto a H22 head (grinding/cutting of the distributor legs) but yes any 92-95 Civic distributor will work.
Old Jul 28, 2003 | 08:21 AM
servion's Avatar
Default Re: H22a1 distributor (Newman)
So: any 92-95 dist will work fine on the h22 motor, but it will not bolt on without a little cutitng of the legs?
How many of the 3 legs will you have to cut/grind to get it to bolt on? I.e., can you get it to bolt on correctly and securely? Will you still have the full range of timing adjustability that you get with a stock h22 dist? A 92-95 dist. will definitely be easier to find...
Old Jul 28, 2003 | 09:16 AM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> that is correct I just did this last week.. also the civic dizzy sits # 1 at a totally different spot than the H22 dizzy but it will work with modification.
djsire
Sep 9, 2012 09:52 PM
wheelmaneg6
Feb 24, 2007 07:05 AM
esca
Aug 20, 2004 11:44 PM
ricekiller1
Apr 12, 2004 08:53 PM
jdmcivicferio
May 27, 2003 10:17 PM
