h22a timing HELP!
i have a few questions about timing ive searched but it didnt answer my questions so far ive seen a white hash some what like a plus and the number 10 my questions is what is the service conector and how do i jump it and what do i line up the white mark with i saw somehtin kind of like crosshairs is that it?????
Punctuation is your friend. Please add some periods and commas and retype so I can understand what you are trying to ask. I'm not trying to be mean, but I really don't understand what you are typing.
ok cool im trying to time the car, and im looking
into the rectangle hole which shows the flywheel. now which marks do i line up with each other to put it at stock timing? i saw a few things like the white hash that looks like a plus few numbers and a crosshair type of thing, like what would be on a gun. can u tell me what to do?
line up the pointer on the block with the white mark on the flywheel. when you look through the hole, the center pointer should be in the center of the 2 pointed pointer.
as for the service connector, it is under the passenger side of the dashboard. it might be kind of hard to get to. its a 2-pin connector. you unplug it, and use a paper clip or small piece of wire and connect the 2 pins together on the female plug.
