h22a engine code 22
when i drive my car after it warms up the engine light comes on and throws code 22. that is the v-tech pressure switch. i switched the hole assembly and i am still getting the code.
any help would be awsome
Hey when you replaced the switch how did you get the green connecter off of the old switch?
But the 22 can be associated with alot of things.
Check oil level.
Clean the filters in the vtec solenoid, and the filter between the pressure switch and the block.
Check grounds and all wiring.
Check oil level.
the green switch came on the new assemble, plug and play.
oil was ok,
the little screen in the switch it self was clean,
it gets very hot under my after i have been driving i was thinking that had something to do with it
oil was ok,
Hey do you have the part number for the switch?
Thanks
I don't think heat would have anything to do with it, as I live in Vegas and 100+ degree days and don't think that was my problem.
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 accord H22a »</TD></TR><TR><TD CLASS="quote">what's up my car went one whole day without that dam light coming on
Loose connection (wires) maybe.
