H22a in Ej1 wont start! Need help!
Old Apr 12, 2012 | 11:32 PM
2sLoJR's Avatar
Default H22a in Ej1 wont start! Need help!
Heres the run down, 97 h22a, theres no crank at all. Nothing.
Fuel pump is kicking in.
Battery is grounded and good.
Starter was checked out and passed test.
Grounds are good.
What the heck is wrong??
Any help would be appreciated im getting really frustrated over here...
Old Apr 12, 2012 | 11:36 PM
jbpnoman's Avatar
Default Re: H22a in Ej1 wont start! Need help!
I assume you mean the starter was tested outside the car? Does it engage and spin when attached to the tranny? If it doesn't, I would start by making sure you're getting power to the starter. If you are, check the signal wire to see if you're getting signal to it when you turn the key.
Old Apr 12, 2012 | 11:53 PM
2sLoJR's Avatar
Correct, had the starter tested outside the car. starter is engaging, i'll check for signal tommorow. Maybe thats what it is
Old Apr 12, 2012 | 11:58 PM
jbpnoman's Avatar
Well if the starter is engaging when mounted ot the tranny, the signal isn't the problem.
I'm assuming it's a 5 speed? Pull the flywheel guard and look at the flywheel while cranking the car. The flywheel should spin. If it doesn't, you have starter engagement issues. If it does, you're either having a fuel or spark issue, and we can get to those later.
Just for clarity sake, are you using the full H22A with transmission, or are you using an H2B setup?
Old Apr 13, 2012 | 08:03 AM
2sLoJR's Avatar
Using a 5 speed h22 transmission as well. Motor is a 97, trans is out of a 95. I'll see if my flywheel moves at all, while we try an crank. I moved the flywheel a little through the crank bolt I heard it click and engage the starter but still nothing.
Old Apr 13, 2012 | 08:07 AM
2sLoJR's Avatar
Flywheel is not spinning at crank. So Im guessing im not getting power to the starter properly?
Old Apr 13, 2012 | 10:39 AM
2sLoJR's Avatar
Bump
Old Apr 13, 2012 | 01:08 PM
Former User's Avatar
Dead battery?
Old Apr 14, 2012 | 05:50 AM
jbpnoman's Avatar
Either you aren't getting power to the starter, or it isn't engaging. When you turn the key, do you hear the starter spinning? If you do, then the starter gear isn't engaging and you need to replace it. If you don't, you either A) aren't getting power to the starter, or B) you aren't getting power on the signal wire.
Start off with the simple thing first - Test the battery. If it checks out, read on.
First, make sure your power wire from battery to fuse box, and then from your fuse box to starter are both connected and in good condition. If they are, get a voltmeter and test to see if you're getting power to the wire at the starter with the key on. If that all checks out, put the voltmeter to the signal wire on the starter and have a friend try to start the car - you should get power to the signal wire with the key turned to crank the car. If you're getting power on the main cable, as well as the signal cable, but don't hear the starter whirring up, you need to check your grounds.
After you've done some diagnoses, maybe we can help figure this out.
Old Apr 14, 2012 | 06:55 AM
ef9_lover's Avatar
had similar problem turn out to be the plug that goes into the starter was loose and wasnt making contact.....squeezed it down to make it a tight fit.... in my h2b it fired up first time
wire that goes here
Old Apr 14, 2012 | 12:27 PM
2sLoJR's Avatar
Battery is good, the male connecter on the starter is fine and not loose.
Jbpnoman- I got my voltmeter and tested the wire from the battery to fuse box, that checked out fine, I tested the signal wire while my buddy was cranking that checked out like you said and Im getting power. Then I tested the main wire connecting to the starter and im getting no power or voltage reading. I think you found the problem.
Old Apr 27, 2012 | 07:16 PM
hdragster's Avatar
Check your kick panel for fuse, might be a bad hardness
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
oneforce
16
Jun 22, 2006 08:19 AM
classciv
Dec 18, 2005 11:53 AM
RiCE On IcE 2
Apr 25, 2005 10:17 AM
BoM
Mar 29, 2002 04:13 PM
