h22a ecu
Old Oct 8, 2002 | 08:57 AM
youngkow's Avatar
Default h22a ecu
I just got a 2000 H22A. The ecu has an imobilizer. How can I take it off? OR can I use a previous year ECU without the immobilizer? Thanks for all the info!
Old Oct 8, 2002 | 09:34 AM
satan_srv's Avatar
Default Re: h22a ecu (youngkow)
The 1996 Prelude VTEC ECU is OBDII, and has no immobilizer.
However it is for the H22A1 engine (92-96), which has larger injectors...so you mayt need to bump the fuel pressure to get to the same flow with the H22A4 (97-01) injectors
[Modified by satan_srv, 1:34 PM 10/8/2002]
Old Oct 8, 2002 | 10:09 AM
hondaZvic's Avatar
Default Re: h22a ecu (satan_srv)
ya.. alll 97-01 prelude ecus have immobilizer, u either have to get a 96 obd2 ecu or a 93-95 p13 0bd1. the p13 would be better though. a lil more power.
Old Oct 8, 2002 | 10:11 AM
Kamin's Avatar
Default Re: h22a ecu (hondaZvic)
96 and 2000 are diffrent versions of OBDII
i dont think the plugs are the same.
Old Oct 8, 2002 | 10:24 AM
satan_srv's Avatar
Default Re: h22a ecu (KAMiN)
OBDII plugs are the same
Old Oct 8, 2002 | 11:22 AM
youngkow's Avatar
Thanks for all your help!!!
Old Oct 8, 2002 | 03:01 PM
SilverEk3dr's Avatar
I am running an OBD2 P13 on my 99 H22a4 and it runs really nice......and thats without tuning. The only prob is that the 99 civic doesnt have a purge flow switch that the 96 p13 looks for....so you will get a cel after two drive cycles...and your car will run like crap for a minute after you fill it with gas (dont know why but thats what mine did) The "purge flow switch" is only 70 bucks.....and is only 2 wires...so its no biggie....
Mark
Old Oct 9, 2002 | 06:31 PM
eghatch22a4's Avatar
Default Re: h22a ecu (SlvrEj6Dx)
Mark
so u can easily fix the pure flow switch and everything for 70 bucks.....andi m guessing that the p13 is the best ecu to use..i thought te p13 was obd1.......u use a conversion kit???.....i wanted to use the p5p ecu but i heard dat u cant use it.....
Old Oct 9, 2002 | 09:11 PM
hondaZvic's Avatar
Default Re: h22a ecu (eghatch22a4)
the 93-95 prelude vtec is a p13 obd1, the 1996 prelude vtec is p13 obd2.
Ty.jon
Oct 8, 2018 08:20 PM
importzero
Jun 23, 2010 08:26 PM
GoFastOrGoShlow_HNDA4LIF
May 9, 2007 05:01 AM
ki11a8ee
Apr 21, 2003 07:01 PM
