H22a axle problem
Old Feb 14, 2012 | 08:56 PM
manchildteggy's Avatar
Default H22a axle problem
Hey guys I recently swaped a full h22a into my eg and I used 93 integra da axles. The drivers side is fine but the passenger side axle keeps popping out, what oem axle can I use??? sorry I dont know what half shaft im using but someone told me I can use the 89 integra axle for the passenger side is that true...thanks in advance
Old Feb 15, 2012 | 07:49 AM
cvcrcr99's Avatar
Default Re: H22a axle problem
Integra axle with a prelude inner. I have some hasport axles on my swap and I am having binding issues. People say that integra axles with prelude inners are the only way to go.
Question since I have never had to deal with this yet. When the axles pops out, do you have to pull everything apart to put it back into the transmission, or can you just jack up the car and slip it back in?
Old Feb 15, 2012 | 02:47 PM
Hasport's Avatar
if an axle pops out then there is a problem with the c-clip
replace the c-clip with a honda one and you are good to go
there is no stock axle combination that is short enough for h22 swap axles
when using a hasport mount kit and hasport axles there shouldnt be any binding issues but lets face it these cars are coming up on 20yrs old and every one is different
binding issues are usually due to a length problem. axle length is easy to check on a car. with the car sitting on the ground remove the axle nut and push the end of the axle back into the hub until it stops. flush with the hub is ideal length. the axle can be 1/4" in or out of the hub and still be within spec.
Old Feb 15, 2012 | 06:38 PM
Thanks! for the past couple of weeks when the axle comes out I just simply put it back in and add oil to the tranny becuase it leaks once its out of the tranny. So prelude inner joints is the only option as far as oem axles? I am definitely going to try to replace the c-clip and see how it goes. I don't have spare cash to buy Hasport axles or else I would of bought them so I'm just trying to get on the road safely now lol
Old Feb 15, 2012 | 07:09 PM
hondasdohc's Avatar
I used a 94 integra axle on the passenger side maybe its a bit longer because mine does not pop out and i have done countless 130 mph pulls on my 4dr ej never had a problem.
Old Feb 16, 2012 | 06:25 AM
cvcrcr99's Avatar
Yea, I have been working with you via E-mail. We are at the point of compressing the axle and getting an overall measurement for you. I have two sets of Hasport axles at this time. I was going to measure the set which is out of the car. I have been working with Chris over there. I have been lazy in regards to getting back to him. My son and living situation which has been changing is taking a lot of my free time up recently. I apologize for any delay in replying.
spraymaster
13
Sep 21, 2011 01:19 PM
jdm_obsession88
Aug 29, 2009 08:10 PM
butter99
Nov 30, 2008 12:49 PM
munk
Mar 20, 2006 06:40 AM
NikoZai
Jul 28, 2002 09:21 PM
