h22 swap problem?
Old Jan 31, 2005 | 03:17 PM
95accordh22a's Avatar
Default h22 swap problem?
was wondering what i can do for a map sensor on my h22 swap 95 accord, is there anyway i can use the one on my throttle body from the accord even tho the preludes is on the firewall also if i cant what others can i use
Old Jan 31, 2005 | 03:37 PM
92acclude's Avatar
Default Re: h22 swap problem? (95accordh22a)
Sport compact car used one from a 90-93 civic dx, which they mounted to the firewall. Check out their website or wait until somebody else who knows what they're talking about tells you. http://www.sportcompactcarweb.com
Old Jan 31, 2005 | 03:56 PM
stitruk's Avatar
i have a usdm h22 and a jdm h22...i used the usdm throttlebody on the jdm h22...yeh i know the jdm tb is bigger...it still works. you might wanna try switchin tb's from your accord to the h22 if it will fit. im not 100% sure, worth a try.
Old Feb 1, 2005 | 07:56 AM
95cxh22a's Avatar
Default Re: (stitruk)
just unscrew the map from the tb and make a bracket to mount it to the firewall. i used my stock cx one.
upgrayedd
Apr 15, 2011 09:35 PM
95accordh22a
Feb 2, 2005 02:23 PM
nickg11111
Sep 26, 2002 08:31 PM
HidPerf
May 23, 2002 09:23 PM
