h22 swap help!!!
Old May 2, 2007 | 09:26 AM
ludatic98's Avatar
Default h22 swap help!!!
i recently did this swap in my 92 dx. i am running a si harness on it that i extended. it is in time and has about 200lbs of compression across the board. but for some reason it is not getting fuel on 2 and 3 i checked the wires with a noid light and the are flashing. i have already swapped injectors off of an extra fuel rail i had and still nothing. i put a brand new header on it and 1 and 4 are already turned gold but 2and 3 are still the crome color.
any suggestions? cuz i dont know.
Old May 2, 2007 | 12:37 PM
ludatic98's Avatar
Default Re: h22 swap help!!! (ludatic98)
bump for a little help.
Old May 3, 2007 | 10:45 PM
fltblkcrx's Avatar
i'm not sure but it sounds like you are running in a "limp mode". have you tried driving it yet? does it bog past about 4,000 rpm?and check engine codes? try checking all sensors and vacuums, makes sure they are correct.
Ajsbored
Mar 4, 2014 11:24 PM
Blogna
Feb 24, 2011 03:07 AM
hybrid2007
Feb 22, 2008 03:46 AM
Stationwagon
Jan 21, 2006 06:05 AM
13secondmonster
May 14, 2004 07:23 AM
