h22 p2v question
Old Jan 5, 2011 | 04:06 PM
93h2beg's Avatar
Default h22 p2v question
i have a 97 usdm h22, i will be stroke-n-it soon with the f22 crank and rods. what i wanna know is that if the piston is 0.020 out of the hole will i run into p2v clearance problems running type s cams?? will i have to fly cut the pistons or run a head shim that is 0020 thick?
Old Jan 5, 2011 | 06:05 PM
SL0WEGG's Avatar
Default Re: h22 p2v question
There's only one real way to tell, check it yourself.
Old Jan 5, 2011 | 10:06 PM
93h2beg's Avatar
are u kidding??? isnt this the common easy stroker??? nobody knows????? wow.
Old Jan 6, 2011 | 04:24 AM
SiR_Chris's Avatar
I think as there are variables involved it is always best to clay the engine yourself to be sure. I'm doing the same with Mahle 11.5cr pistons and stock head. I know it will be ok, but want to make sure for myself lol
Old Jan 6, 2011 | 08:37 AM
h22aspanky's Avatar
first if you are doing a 95mm stroker you should be using the f22 rods and h22 pistons and it should not come out the deck a h23 is a h22 block with f22 internals wich consists of a 95mm crank with matching rods
Old Jan 13, 2011 | 08:38 AM
93h2beg's Avatar
zeal auto werks compression states it will stick out 0.020,
h23 or f22 rods... ive changed my mind, i am just doing a type s build with a tad more compression and cam will be assembling my motor tonight
street_ride14
Sep 27, 2010 09:55 AM
Libertariat
Sep 5, 2007 10:08 AM
brycemartin
Nov 27, 2005 05:42 PM
yohan
Sep 23, 2004 11:39 PM
GSRswapandslow
Sep 2, 2003 06:42 PM
