H22 mount kits
Old Jun 8, 2003 | 04:03 PM
RabbittZ's Avatar
Default H22 mount kits
ok i cant remember who i talked to a while back.. but i remember talking about HCP and hasport h22 in eg hatchs. one kit is reversable, being able to go back to stock and ones not.. can someone help me out... DUDE I CANT FIND YOU! whoever you were...
Old Jun 8, 2003 | 04:16 PM
junglerunna's Avatar
Default Re: H22 mount kits (RabbittZ)
Im pretty sure its the HCP kit that is reversible.
Old Jun 8, 2003 | 04:29 PM
Turbogixxer's Avatar
Default Re: H22 mount kits (junglerunna02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty sure its the HCP kit that is reversible.</TD></TR></TABLE>
Correct, thats what they claim
Old Jun 8, 2003 | 04:33 PM
Default Re: H22 mount kits (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Correct, thats what they claim</TD></TR></TABLE>
I thought so, but yet again I have never read, heard, or saw anyone that previously had an h22 and then swap it out for a B or D series engine. So...
Old Jun 8, 2003 | 04:36 PM
NorthernXposure's Avatar
you have to do some trimming on the passenger mount with the HCP kit.. at least i did with mine anyway.. i wouldnt really consider it as a "reversable" kit because you would still have to weld to get you d or b series motor mounts to fit back in...
Old Jun 8, 2003 | 04:37 PM
RabbittZ's Avatar
Default Re: H22 mount kits (NorthernXposure)
well if you have to shave the HCp.. then it might of been the hasport kit that you can just reverse
Old Jun 8, 2003 | 04:42 PM
has sport requires you to remove the whole mount off the passenger side
Old Jun 8, 2003 | 04:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthernXposure &raquo;</TD></TR><TR><TD CLASS="quote">you have to do some trimming on the passenger mount with the HCP kit.. at least i did with mine anyway.. i wouldnt really consider it as a "reversable" kit because you would still have to weld to get you d or b series motor mounts to fit back in...</TD></TR></TABLE>
I never had to shave my HCP ek-22 mount kit.
Yeah, the amount that you have to shave off the mount to make it not grind 5th and reverse makes the mount useless.
Old Jun 8, 2003 | 04:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RabbittZ &raquo;</TD></TR><TR><TD CLASS="quote">well if you have to shave the HCp.. then it might of been the hasport kit that you can just reverse</TD></TR></TABLE>
talk to poison, he reversed a HASport mount kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">I never had to shave my HCP ek-22 mount kit.</TD></TR></TABLE>
I think that it is only for EG.
Old Jun 8, 2003 | 05:33 PM
fastwanabe's Avatar
both kits are reversable with welding..... however the HCP kit would be easier to reverse instead of welding in the entire mount back in(HASport)you just to weld in the piece of mount you cut out with the HCP.
Old Jun 8, 2003 | 06:58 PM
UpstateCivic's Avatar
Default Re: H22 mount kits (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">both kits are reversable with welding..... however the HCP kit would be easier to reverse instead of welding in the entire mount back in(HASport)you just to weld in the piece of mount you cut out with the HCP.</TD></TR></TABLE>
Precisely.
Old Jun 8, 2003 | 10:56 PM
Newman's Avatar
New User
I never had to shave my HCP ek-22 mount kit. </TD></TR></TABLE>
That is what's nice about the EK engine bay... no cutting or welding needed as all of the 96-00 Civic engine bay layouts are the same (even auto & 5-spd cars.... not like the EG where the pass framerail mount is different). So on the EK, you bolt on a plate to the framerail, and that is what has the arms extending out to hold the transmission mount onto.
Old Jun 10, 2003 | 07:51 PM
RabbittZ's Avatar
hmmm im still sceptical.... i guess i just have to call each company and see how each works out
Old Jun 14, 2003 | 08:28 AM
vtecjag's Avatar
Default Re: (RabbittZ)
yo i have the hcp kit and you have to cut or grind the transmission side mount to make clearance so you couldnt change it back to any other swap....
Old Jun 14, 2003 | 04:36 PM
Default Re: (vtecjag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjag &raquo;</TD></TR><TR><TD CLASS="quote">yo i have the hcp kit and you have to cut or grind the transmission side mount to make clearance so you couldnt change it back to any other swap.... </TD></TR></TABLE>
What model civic do you have? Like people stated in a EG its not a direct bolt in the mounts. Unlike the ek.
Old Jun 16, 2003 | 12:23 PM
vtecjag's Avatar
Default Re: (junglerunna02)
i have an eg6, and loving every minute of it..
Old Jun 18, 2003 | 05:54 PM
RabbittZ's Avatar
yeah i have a eg also.. but yeah.. what if i had to do some welding, then i should be able to switch back correct?
Old Jun 18, 2003 | 06:42 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RabbittZ &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have a eg also.. but yeah.. what if i had to do some welding, then i should be able to switch back correct?</TD></TR></TABLE>
yes.
Old Jun 18, 2003 | 08:32 PM
Newman's Avatar
New User
Default Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have a eg also.. but yeah.. what if i had to do some welding, then i should be able to switch back correct?
yes.</TD></TR></TABLE>
I'll have to take a picture tomorrow on a spare clip that we have that was originally used for test fitments with HCP's mount kit. There's a small piece welded back onto the frame bracket, so minimul modification/welding is needed to put a stock B/D-series motor back, but it should show what is needed to be done to the frame mount.
DC2_Project
Sep 9, 2006 02:49 PM
NA-Cutie
Jan 31, 2005 05:14 PM
projectTeG
Dec 23, 2003 05:14 AM
Newman
Sep 30, 2003 08:46 PM
wm5holla
Jun 9, 2003 11:40 PM
