h22 fuel problem
Old Mar 10, 2005 | 07:33 AM
SiR EJ8's Avatar
Default h22 fuel problem
this is my problem. i have a stock h22a with walbro 255 fuel pump. the regulator is an ericks racing. for whatever reason, im blowing fuel out of my exhaust pipe. anyone know the reason for this?
Modified by SoLo Accord at 1:39 PM 3/12/2005
Old Mar 10, 2005 | 08:10 AM
C M S's Avatar
Default Re: h22 fuel problem (SoLo Accord)
What is your FP set at?
Old Mar 11, 2005 | 03:15 PM
IHateJDM's Avatar
Default Re: h22 fuel problem (1SICJDM)
What ECU are you using?
I have the same fuel pump on my h22, and I've had the same problem. I was running a chipped p28 ecu, and tried out a p13 for the first time a few weeks back. I was still running a little rich, but not even close to as bad as before. My obd1 p13 arrives in a few days .
Old Mar 12, 2005 | 09:51 AM
SiR EJ8's Avatar
i am running a p28. the FPR was just getting over pressureized with fuel. so, i took out the pump and put in a stock EX pump. pressure is back to normal.
however, i am having a problem with my CEL. i wired it up and now it is just staying on. when i "plug" it with a paper clip, it does nothing. just stays solid. any ideas?
btw, this motor is in a 96 EK CX.
Old Mar 12, 2005 | 09:53 AM
SiR EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote">What is your FP set at?</TD></TR></TABLE>
even with turning the FPR up and down, it stayed at a constant 60psi. so, i removed it, and so far so good. except for running in "safe" mode i guess. i am running rich as hell and the car barely runs. i have to keep it running with the throttle. read above post for problem.
Old Mar 12, 2005 | 10:35 AM
NXLude's Avatar
60 psi at idle?! I hope not....thats way way too much. I run a 255 pump with noproblems....whats the psi at idle?
Old Mar 12, 2005 | 10:38 AM
SiR EJ8's Avatar
Default Re: (NXLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">60 psi at idle?! I hope not....thats way way too much. I run a 255 pump with noproblems....whats the psi at idle?</TD></TR></TABLE>
yes. 60psi at idle. i changed the pump. now i cant get the CEL to blink when i jump it.
Old Mar 12, 2005 | 10:42 AM
NXLude's Avatar
An h22 should be runnin 38-42 psi at idle.....you are running way way way way too much pressure into there. That is your problem. Your cel will be related to an extreme rich condition. Replace your 255 pump back into there and adjust the pressure down to 40 psi and your cel will stop and it will run fine again
Old Mar 12, 2005 | 10:50 AM
SiR EJ8's Avatar
« » 12:51 PM 3/12/2005 Reply Edit
New post:
i already replaced it. psi is at 40!!!!!!!! so, the CEL would NOT be due to the richness!!
Old Mar 12, 2005 | 10:55 AM
NXLude's Avatar
If you were running at 60 psi at idle yyou will get a rich cel. I got a rich cel (with a walbora 255 and p28 at 44 psi). You can run a 255 pump on a h22 with a p28, Ive done it for quite a while.
Old Mar 12, 2005 | 10:57 AM
SiR EJ8's Avatar
the pump is NOT in the car anymore. that cel is not the problem!!!!!!!!!!!! just tell me why i cant get the check light to blink when i jump it?
Old Mar 12, 2005 | 11:01 AM
NXLude's Avatar
not sure, have you reset the ecu yet?
Old Mar 12, 2005 | 07:16 PM
93hatched_projekt's Avatar
If you reset your ecu the code will not blink , the cel light will just stay on. Drive your car for a couple miles and the code will re-appear.
Old Mar 14, 2005 | 07:01 AM
SiR EJ8's Avatar
Default Re: (93hatched_projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">If you reset your ecu the code will not blink , the cel light will just stay on. Drive your car for a couple miles and the code will re-appear.</TD></TR></TABLE>
i have reset the ECU. and, the light stays on even while driving. it never turns off or blinks when i jump it.
Old Mar 14, 2005 | 07:15 AM
IHateJDM's Avatar
Default Re: (SoLo Accord)
Has you cel always been on, or did this just start recently? A cel that is constantly on and does not show a code could be a bad ecu.
Old Mar 15, 2005 | 02:28 PM
SiR EJ8's Avatar
the ecu is good because im able to drive the car. i hard wired the fuel pump to a switch just for temp. purposes. could that possibly be the reason.
Old Mar 15, 2005 | 04:43 PM
IHateJDM's Avatar
Could be, at least sounds like a good place to start.
Old Mar 15, 2005 | 04:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLo Accord &raquo;</TD></TR><TR><TD CLASS="quote">the ecu is good because im able to drive the car. i hard wired the fuel pump to a switch just for temp. purposes. could that possibly be the reason.</TD></TR></TABLE>
Do you mean you wired up like a fuel pump kill switch? If so I've done that without throwing any cels. Hows your car running? As far as your cel light staying on without being able to pull a code , I've heard if you harm the jumper by pushing to hard on the input you can either damage the ecu or jumper , but dont quote me on that.
Old Mar 15, 2005 | 04:47 PM
. o 69 o .'s Avatar
im running a 255 on my h22. I have a custom chipped p28, and a b&M regulator. For the life of me i cant get the fuel pressure to go below 42-44 psi. Im thinking of going down to a walbro 190.
Old Mar 15, 2005 | 05:02 PM
IHateJDM's Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">im running a 255 on my h22. I have a custom chipped p28, and a b&M regulator. For the life of me i cant get the fuel pressure to go below 42-44 psi. Im thinking of going down to a walbro 190. </TD></TR></TABLE>
Yeah, I've got a 255 on my h22 too. Also running a chipped p28. I'm running rich as hell, and I've heard that's common with p28's for some reason. I'll be trying out an stock p13 and see if it leans out a little. I'll let you know if it helps. Got to wait til the car is out of the shop first though, damn soccer moms with their suv's and cell phones.
boostedjd
Engine Management and Tuning
Jul 3, 2013 06:05 PM
JDM_COUPE
26
Mar 4, 2008 09:05 AM
honda9369
Sep 22, 2004 02:44 PM
Kp_VtekNiks
Oct 11, 2003 08:48 AM
