h22 external coil help!!!!!
Old May 24, 2007 | 05:52 PM
turboh22civic's Avatar
Default h22 external coil help!!!!!
i have an h22a1 in a 95 eg hatch. well i wired up everything correctly and did every thing by the "book" and now im down to one thing the externally mounted distributor coil.... i dont know where to splice the wires into?...the coil has its own seperate pigtail connection on it with three wires on it (1-yellow, 2-black/yellow, 3-green) will anyone PLEASE HELP MY WITH SOME INFO HERE... ONLY THREE WIRES LEFT TO GET MY CAR GOING....... I NEED ANYONE WHO CAN GIVE ME INFO ON HOW TO DO IT OR WERE TO LOOK UP AT TO DO THE WIRING....THANKS AGAIN AND ALL COMMENTS ARE APPRECIATED!!!!
Old May 24, 2007 | 07:02 PM
powerflow's Avatar
Default Re: h22 external coil help!!!!! (turboh22civic)
What side of Houston are you in, send a pm if you can, I might be able to help.
Old May 24, 2007 | 07:17 PM
Default Re: h22 external coil help!!!!! (powerflow)
hey im in conroe texas near exit loop 336 if so can u help me asap please i need to get it running cause im tring to go out of state for family emergency
Old May 25, 2007 | 05:26 AM
Mikey3000's Avatar
i THINK you put the yellow and yellow/black wires together, and send a wire from that junction to the black/yellow wire (2 plug connector) on the distributor. then the green wire goes to the blue wire on the same 2 plug connector on the distributor. i remember having to put 2 wires together but i dont recall the wire colors, i did this about 5 years ago.
niterider96cord
Feb 3, 2010 05:04 PM
jonnyt1130
Aug 3, 2009 04:55 PM
posaccord01
Mar 24, 2007 08:40 AM
blacks13ek
Dec 21, 2004 10:42 AM
