h22 eg -dss level 2 problem-
Old Oct 10, 2003 | 02:29 PM
93hatched_projekt's Avatar
Default h22 eg -dss level 2 problem-
Just got my swap in , and my dss level 2 hybrid axle (passenger side) seems to be too long.I cannot lower the car too much , cuz I get real bad vibrations, any time I hit bumps . I was just curious to know if anyone has had this same problem. My setup is hcp mounts, jdm h22 in a 93 hatch...... I remember a few threads back in the day that resembled my problem,but cannot find the thread.......any comments will be appreciated................
Old Oct 10, 2003 | 02:39 PM
poison's Avatar
Default Re: h22 eg -dss level 2 problem- (93hatched_projekt)
Does the inner cv joint go into the tranny and lock in just fine? And does the factory damper fork clear the axle shaft then the car is lowered?
I would contact DSS about the problem.
Old Oct 10, 2003 | 03:26 PM
Default Re: h22 eg -dss level 2 problem- (poison)
The fitment on the axle seems to be fine , no leaks so far and the joint mounted good,it's just when the car is lowered and I hit bumps I get sick vibrations ........I dont know what it is ,but I just got them in. When I raise the car like 2" it seems to be fine . I will contact dss first thing ......I just wanted to see if this has happened to anyone.............Thanks
Old Oct 10, 2003 | 03:30 PM
poison's Avatar
Yep, I have seen it happen before around here. There are several others on the board that have this problem.
I would contact Frank at DSS on the issue.
Old Oct 10, 2003 | 04:37 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Yep, I have seen it happen before around here. There are several others on the board that have this problem.
I would contact Frank at DSS on the issue. </TD></TR></TABLE>
Yep, Had the same problem with my stage one hybrids. Actually the bar they used for my passenger side axel was just a tad too long. Contacted Frank at DSS... sent a new one 3 day air. Then had UPS pick up the old axel the next day. Great customer service and handled the problem very quickly.
Old Oct 10, 2003 | 06:07 PM
BlackJDMdeath's Avatar
hmmm i guess this would be the place to ask about opinions on using the stage 1 hybrid axles on an ek/h22a with hondata and nitrous, most likely a 75 shot.
the nitrous may be set up as a wet system with alcohol injection on the nitrous and a progressive box, just have to talk with dale about the hondata being able to control a wet system, being as the site indicates it only controls a dry shot
Old Oct 10, 2003 | 09:08 PM
Tyler H's Avatar
Frank @ DSS knows about the problem. Same thing happened to me with my stage 5's. He said that HCP took the measurements and that's what he sends out. Every once in a while he'll get a call where the passenger side is too long. Try this: take off your spindle nuts and push the axles into the hub. The splines should move about half an inch. I bet you won't have any movement on the passenger side. Just give him a call. He sent a new one right out to me. Great customer service.
Old Oct 10, 2003 | 09:13 PM
ozzyman's Avatar
Default Re: h22 eg -dss level 2 problem- (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">Frank @ DSS knows about the problem. Same thing happened to me with my stage 5's. He said that HCP took the measurements and that's what he sends out. Every once in a while he'll get a call where the passenger side is too long. Try this: take off your spindle nuts and push the axles into the hub. The splines should move about half an inch. I bet you won't have any movement on the passenger side. Just give him a call. He sent a new one right out to me. Great customer service.</TD></TR></TABLE>
Yup, thats exactly what he told me to do the first time I called him. I had absolutely no slack. The axel would not even move just a little bit. Called him back and sent the new axel out right away. Frank cares about his customers.
Old Oct 11, 2003 | 04:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">Frank @ DSS knows about the problem. Same thing happened to me with my stage 5's. He said that HCP took the measurements and that's what he sends out. Every once in a while he'll get a call where the passenger side is too long. Try this: take off your spindle nuts and push the axles into the hub. The splines should move about half an inch. I bet you won't have any movement on the passenger side. Just give him a call. He sent a new one right out to me. Great customer service.</TD></TR></TABLE>Hmmmm.......thanks for the info I'm gonna have to give your idea a run...............Thanks for the comments.......It sounds like I shouldnt have any problems with dss..............
93h22da
Transmission & Drivetrain
Dec 19, 2011 10:22 PM
jdmegh
May 25, 2007 07:21 AM
EpeG86
Nov 17, 2006 03:55 PM
KStuned
18
Sep 13, 2003 07:39 PM
