H22 dizzy question
Have a obd2a h22a4 in my obd2a 97 honda civic if I run a chipped p28 on a jumper in my car will I have to change to an obd1 dizzy. Obd2 have crank sensors in the block and I think from research obd1 uses the dizzy for the crank sensor. So question is can I use my obd2 dizzy or do I have to get dizzy jumper harness and run an obd1? Ive done research just can not find everything
If you are simply using an obd2 -> obd1 jumper at the ecu, you should leave it with the obd2 dizzy, as the jumper harness does the job of converting for you. At least that is how I understand it.
Well just found out that dude had already put a obd1 dizzy on it so what should I do just get a dizzy harness now, and what about stock obd1 p13 ecu's do they need resistor box for injectors?
rogue3221
Nov 23, 2004 11:36 AM
