h22 in civic
is this a total pain in the ***, is it worth it? what problems will i have? what type of trnny is better and how will i run the linkage, what bout ob2 - 1??? how much will it cost and does any one have any mounts or linkage or axels i could buy???
What model of Civic do you plan to put the h22 in?
It will cost you some money..lots of it.
But when you are finished you will have a BEAST loads of tq and responds well to tuning. GL
me and my friends are abouts to do the swap on saturday, I will tell you how it goes and everything else. I wouldnt say it costs alot of money, altogether on mine I spent about 3500.00, I dunnoe about other people.
http://www.JDMshit.com/hcp/EGfitment
Should start you off in the right direction and give you an idea of what's needed.
you can get a custom pig tail wiring harness to convert it over from, Place Racing, Hasport, HMOnline, and a few other places... they should also have custom shift linkage and shifter cables....or you can fabricate your own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRslowandswap »</TD></TR><TR><TD CLASS="quote">just make sure you get good mounts
either hcp or hasport.
don't skimp on this swap...or you'll regret it.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=535999
One example right there..... working on more.
GC now makes a kit specifically for the eg h22 swap. check it out.....
http://www.ground-control.com
