H22 in 94 teg LS problems
Old Jul 19, 2002 | 07:05 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default H22 in 94 teg LS problems
Good Day folks. I have a bit of a problem with a swap that a friend of mine just completed. The car is a 94 LS, the engine is a 95 J spec H22. So, the engine is in and running, but not well. The idle will not come down below 1700 even with the idle mixture screw all the way in. Also the rev limit is at 6500 rpm. There is no CEL at all. Just wondering if you folks have any ideas at all. Also, we have swapped the TPS, MAP, and checked for vacuum leaks around the IM.
TIA
Clayton
Old Jul 29, 2002 | 12:03 PM
Anyotherone's Avatar
Default Re: H22 in 94 teg LS problems (Clayton)
What ECU are you using?
Old Jul 29, 2002 | 09:56 PM
ahcjar103's Avatar
Default Re: H22 in 94 teg LS problems (Anyotherone)
make sure the throttle plate in the tb is closing all the way at idle
Old Jul 30, 2002 | 04:48 AM
Mikey3000's Avatar
Default Re: H22 in 94 teg LS problems (ahcjar103)
1st do that and if that doesn't work, take off the Fast Idle Valve and make a plate and bolt it in the FITV's place.
projek.t
May 26, 2008 12:53 PM
worrdogg
Nov 4, 2004 03:09 PM
leechungsr
Aug 15, 2001 01:38 AM
