h22 75 shot
my 2000 4 door accord h22a has stage2 cams,cam gears, intake manifold,hondata,v2 cold air intake,pistons,rod,and a 75 shot can the motor hold it and what should i run in the 1/2mile. With the stock h22a motor i ran a 14.9
1/2 mile? I got no idea. 1/4 mile, you should break 13's depending on tires. Its not the easiest setup to get traction with, but Ive seen ludes with similar setups run mid-upper 13s no problem. So Id think youd be somewheres in there too
steph_accord
Nov 26, 2003 07:33 AM
