GSR eagle Rods in LS block?
Can I use my eagle gsr rods in my LS block? Its going to be an LS/Vtec with a B16 head. I also have 9.0:1 compression pistions for a gsr, what will the compression be in a LS block with the gsr rods? thx for the help...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">You can only use the GSR rods in the LS block if you use a GSR crank. The compression won't really change, but the stroke will.
So if I get a GSR crank I can use my GSR rods and pistons and my compression will still be 9.0:1 in my LS/Vtec setup...
