Gauge needels jumping
Old Feb 9, 2006 | 04:05 PM
Hyaboosta's Avatar
Default Gauge needels jumping
I have a b16 in an eg and when I am driving it every so often the tach needle will jump down to 0 and then come back up and jolt around a little. I am thinking that it is a bad ground. anyone have any similar problems?
Old Feb 10, 2006 | 05:21 AM
Hyaboosta's Avatar
Default Re: Gauge needels jumping (Hyaboosta)
bump for some help
Old Feb 10, 2006 | 06:57 AM
Braco11's Avatar
check if any wiring is loose. a lot of times when the tach starts jumping, it's something regarding the dizzy (rotor, coil, etc). i had that problem and it turned out my dizzy was shot.
Old Feb 10, 2006 | 05:45 PM
Supahr_Ed's Avatar
its a wiring problem...do you have a shift light or something hooked up? I had a problem with the wire tapped into my signal wire on the dizzy. It can also be on the speed sensor..another problem i had..check those two for wiring problems..or just disconnect any RPM or shift light guage
masijdm
Dec 17, 2008 12:04 PM
MeatballHB
Dec 14, 2005 11:55 AM
clutch33
Jun 9, 2004 04:28 PM
4gen
Mar 30, 2003 08:51 PM
speedymon
Aug 4, 2002 11:41 AM
