g23 piston dome
Old Oct 25, 2010 | 11:21 PM
jdm.fanatic's Avatar
Default g23 piston dome
I am trying to get a g23 together and I just need to get the pistons to put it together. I want to get custom light wieght ones that give me a high compression ratio and wont have clearance issues. I plan on useing type s cams so nothing too aggressive. How do I figure out how much positive dome I can run? I dont want to order them and then they dont work. I have the f23 with h22 head running e85
Old Oct 26, 2010 | 03:37 AM
hondamark35's Avatar
Default Re: g23 piston dome
H/F compression calculator
Old Oct 26, 2010 | 06:51 PM
That doesn't tell me if it fits, just compression
Old Oct 27, 2010 | 03:11 AM
when you asked how much dome you could run i assumed you meant compression. my bad.
so you're wondering about dome clearance with the chamber and/or valves? i could be wrong, but i'm pretty sure you'd be kissing valves before you hit the head. the only way to check this clearance would be to 'clay' it once it's assembled... but generally any OE honda piston or aftermarket piston made for Honda application should fit without contacting the head (if the compression height is right)
Old Oct 27, 2010 | 03:15 PM
g23beast's Avatar
RSX 12.5:1 compression Probe industries pistons
Old Oct 28, 2010 | 10:52 AM
I want more than 12.5:1 if it will work
Old Nov 2, 2010 | 08:07 AM
Lil Tones's Avatar
You won't be able to run E85
Old Nov 2, 2010 | 09:28 AM
d00mlol's Avatar
False.
Old Nov 11, 2010 | 08:32 PM
Um yeah I can and will need to with the comp. I want
Too-R3ckl3ss
Apr 1, 2012 12:21 PM
crazydominicanman
12
Sep 7, 2011 10:08 AM
be18see1
Oct 28, 2008 07:55 AM
Black R
Dec 1, 2004 07:34 AM
4doorH22
Sep 7, 2001 08:29 AM
