fuel or vacuum?
Old Oct 28, 2002 | 10:22 AM
Leisyman's Avatar
Default fuel or vacuum?
have a 97 CX hatch with H22a Swap. All stock except for clutch. Oh and the wiring...converted CX harness to OBD1 harness and am using Hondata (i think) OBD11 to OBD1 harness conversion. Having hestitation problem when accelerator is depressed. Unless depressing accelerator VERY slowly, the enging bogs and wants to die. If I continue to press accelerator, as revs build the engine bogs, spits. Car is undrivable in this state.
Any advice on what to check for?
Thanks
Old Oct 28, 2002 | 02:31 PM
google's Avatar
Default Re: fuel or vacuum? (Leisyman)
check if the tps isnt switched with the map. Also check the resistance on the tps. what kind of engine harness do you have
Old Oct 29, 2002 | 05:40 AM
Leisyman's Avatar
Default Re: fuel or vacuum? (1320in11)
Mad-Mike
11
Jun 23, 2011 03:40 AM
apice
Mar 19, 2008 03:35 PM
mdoyle
May 25, 2006 11:01 AM
Capsule Kid
Jun 11, 2005 10:25 AM
b16hybridsol
Oct 24, 2003 03:04 PM
