Fuel Pump Question - Type R
I have a STOCK DX fuel pump on my 97 jdm b18c(r) in my coupe. My setup is going to be (in 1dy)
J's Style Racing Intake
98 JDM Type R Header
Carsound Cat
Skunk2 Cam Gears
Apexi VAFC
B&M FPR
I'am going to tune the car and my question is should I get a Walbro255 fuel pump? or is my DX one doing its job?
Carsound Cat
Skunk2 Cam Gears
Apexi VAFC
B&M FPR
Q- So is the DX fuel pump killing my performance? or no, would it w/ tune
Q-What if I get the smaller walbro 190?225?
Need quik answer
Need quik answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. »</TD></TR><TR><TD CLASS="quote">stock is fine. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. »</TD></TR><TR><TD CLASS="quote"> replace the stock one at 220+ whp.</TD></TR></TABLE>
you're about 40 whp shy of possibly considering buying a pump.
not to jack your thread but i have a jdm b16a in a 92 cx. should i swap out my fuel pump? i/h/e, type r im, skunk2 valve train & stage 1 cams
jesus christ...once again:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. »</TD></TR><TR><TD CLASS="quote">replace the stock one at 220+ whp.</TD></TR></TABLE>
you're about 50 whp shy of possibly considering buying a pump.
i had a stock cx feul pump on my turbo set up with no adjustable regulator and 440cc injectors on 10 psi running 12's so i think will be ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">isnt a B-series VTEC pump different from a SOHC No-TEC pump.. i could have swore they were.. educate me.</TD></TR></TABLE>
im pretty sure that they are, im just saying that i got by without one on my set up for a while with a shitty pump
I believe SOHC cam vtec sand non vtec b series use a 79lph pump stock, while B seties vtecs use 135lph pumps stock, you have spent the money on a type r swap, might as well get the correct fuel pump for your motor. just get a stock pump for a gsr for your year car, it should bolt right in. cheap insurance
r0cket247
Jul 26, 2004 11:37 PM
