FOUND - magical VTEC wire...
Old Feb 1, 2002 | 11:55 PM
tinkerbell's Avatar
Default FOUND - magical VTEC wire...
swap was completed about a month ago, still waiting for her to be registered though...
one issue was the code 17 VSS problem. the ECU requires a signal that the car is going over 20mph before VTEC kicks in.
cause my car is an 83 model Prelude i needed to get the signal from the dash console, which uses an optical sensor to determine road speed which then transforms the signal into a square wave type...
anyways! on the back of the cluster there is a little circut that does this and an output is the blue wire marked SP, i hooked up the VSS wire to this output and took it for a test drive...
3000, 4000 - bang!!! she opened up and the intake noise was amazing!
the push in the back was the best! a grin from ear to ear :D
just thought id share this with you guys...
ive got VTEC!!!
t..
Old Feb 2, 2002 | 05:27 AM
6SPD_EK's Avatar
Default Re: FOUND - magical VTEC wire... (tinkerbell)
i gotta see this
edit - ok now that i saw it - i want one too - it musta been very difficult to get the motor to mount properly huh? all you need are some ITR cams and some dyno time to dial it in
[Modified by 2000-4DRGSR, 6:39 AM 2/2/2002]
Old Feb 3, 2002 | 02:02 AM
tinkerbell's Avatar
Default Re: FOUND - magical VTEC wire... (2000-4DRGSR)
ha ha, bring it on!
i cant wait to take it to the track
t..
Old Feb 3, 2002 | 08:15 AM
nutsack's Avatar
how much does the 83 lude weigh?
Old Feb 3, 2002 | 01:13 PM
tinkerbell's Avatar
Default Re: FOUND - magical VTEC wire... (*******)
according to Honda - 955kg or 2100lbs
ive removed all the A/C, the ALB and replaced an iron block with a alloy one...
so it could be as little as 900kg or less than 2000lbs??? not sure.
but its not heavy by any measure.
t..
CrooksEK
Jul 23, 2014 11:45 AM
05 S2K Stoner
Oct 28, 2004 06:40 AM
Propulsion
Jul 22, 2003 12:47 PM
pelotudo
Jan 30, 2002 03:02 PM
