F22B1 in EG Project/Info Thread
Old Jan 29, 2010 | 10:54 AM
AccordVT's Avatar
Default F22B1 in EG Project/Info Thread
Hey guys,
I have mounted, wired and configured the F22B1 (from a '94 Accord EX Manual) into a '95 Civic DX Automatic. My Accord was up for winter and I have plans to do a J series RWD project someday. So the motor and trans were just asking to be put into my EG. I still have some work to do before it is on the road. The majority of the auto/manual conversion and the modifications to fit the engine are complete though. The axle geometry seems to be good, the shifter cables work nicely (routing was difficult but is crucial).
Main Components I used:
Mounting
> Innovative 92-95 Civic, 94-01 Integra Conversion Mount Kit for H22 Swaps (Steel)
> 90-93 OEM Accord Drivers Side Mount Bracket
> OEM Prelude (H22a) Rear Engine/Trans Mount Bracket
Drivetrain
> H22 Custom Swap Axles
> 94 Accord Clutch Slave Cylinder
> EG Clutch Master
> DX Accord 5spd Trans
> LUK Pro Gold Clutch
Other
> 94 Accord Throttle Cable
> MSD Blaster 2 External Coil
> OEM EG Rad
> Acura Legend A/C Condenser Fan (Front Mounted, Push)
> DC Header for Accord combined with o2 mounting pipe from accord exhaust system allows for a bolt on exhaust
If anyone is thinking about this swap, is in the process or are just curious, feel free to ask
Old Jan 29, 2010 | 12:16 PM
supra-n-civic's Avatar
Default Re: F22B1 in EG Project/Info Thread
cool i guess. but its been done quite a few times before really. its the same as any h or f series swap
Old Jan 30, 2010 | 06:51 PM
AccordVT's Avatar
I posted more for the purpose of people needing pictures of certain things, or discussion on the specifics of the F22B1 in the EG. I really didn't think I was the first or it was the most extravagant swap.
Old Jan 30, 2010 | 07:41 PM
ashb82's Avatar
I did this swap it runs good. I could out run most b series swaps. I turboed it and would run 7.8 in the 1/8th. fun swap f22 can handle boost and nos better that other honda engines due to the stock low compression
Old Jan 31, 2010 | 06:49 PM
AccordVT's Avatar
Yeah maybe someday I will end up boosting it a bit. It ran really strong when I had it in my Accord...really took a beating. I would think 250-300whp would be safe and streetable.
Yea, the F22B1 has cast iron sleeves, 8.8:1 compression, it makes it's 147 ft. lbs. of torque at 4,500rpm, you can find complete, low mileage engines for under $500. The aftermarket support is decent too, better than a few years back. KMS engine development and Bisimoto engineering have a lot going on.
Old Jan 31, 2010 | 09:33 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
pretty sweet. I always wanted a eg with a BIG sohc those motors make really good powerbands for street cars.
Old Jan 6, 2016 | 09:07 PM
94 civic jb's Avatar
How much where the axles and mounts? And did you have to use those other mounts too? Cuz I'm taking one from an Acura CL and don't know if I would use the same mounts as you did
Old Feb 29, 2020 | 02:41 PM
Steven Perez's Avatar
Originally Posted by AccordVT
Hey guys,
Mounting
Drivetrain
> EG Clutch Master
> LUK Pro Gold Clutch
Other
> OEM EG Rad
trying to do the same swap I have 93 eg with a b20 but kinda bord of the same swaps all the time I wanna try something different since I have a f22 b1 motor and trny just laying in my garage what harness do I need and what ecu ?? Would really appreciate the help
Old Nov 20, 2020 | 09:02 PM
Vutha Ren's Avatar
Hey guys,
Mounting
Drivetrain
> EG Clutch Master
> LUK Pro Gold Clutch
Other
> OEM EG Rad
Can you help me with this swap?? I have a f22b1 vtec motor that is a spare motor from a manual swap I did on my accord.. but I want to put the motor in use into a eg.. can you tell me how it is done and how the whole axle deal works.. and how the wiring went? Does the eg wiring harness plug right up to the motor??? Please I am really wanting to know ..
vindeezl
Nov 5, 2017 11:08 PM
hindelk
Mar 9, 2012 10:14 AM
fabe85
Jun 18, 2007 09:32 PM
JBk24crx
Apr 16, 2005 01:35 PM
seeNATgo
Oct 16, 2002 11:13 AM
