where is it located?? i'm using a 00 SI B16 TB, on a ITR IM, please help, thanks
also what IAC can i use with the ITR IM??
Modified by Convoy at 8:03 PM 2/8/2004
b16 tb dosnt have one.
almost all IACV's are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convoy »</TD></TR><TR><TD CLASS="quote">where is it located?? i'm using a 00 SI B16 TB, on a ITR IM, please help, thanks
The FITV is located on the under section of the throttlebody. Not all tb's have an FITV. Coolant runs through the FITV to keep the throttle plate/butterfly from sticking in cold climates. On some vehicles, it helps maintain idle.
You can use any IACV from any of these vehicles for your ITR IM:
92-95 Si/EX
94+ Integra LS
96-00 EX (5speed only)
99+ Si coupe
Modified by Katman at 1:40 PM 2/9/2004
92-95 Si/EX
94+ Integra LS
99+ Si coupe
