engine won't turn over help
Old Jul 19, 2004 | 05:55 PM
length's Avatar
Default engine won't turn over help
Having trouble starting motor. Sypmtoms.
-set up
92 si hatch
00 d16y7 motor
engine turns over, and the spark is there at the dizzy. Not at the plugs. Could be wires.
I reused the injectors, intake mani, exhust mani, alternator, and harness.
does anyone know what could be the problem? or has anyone encountered a problem like this and knows any insite as to why its not working properly?
share your info thanks in advance.
Old Jul 19, 2004 | 06:30 PM
Redline130's Avatar
Default Re: engine won't turn over help (Jdm Ek Hatch)
Change your wires and see if that's the remedy to your problem. Also, check all of your grounds and make sure that they are secure.
Old Jul 19, 2004 | 06:58 PM
hondaZvic's Avatar
Default Re: engine won't turn over help (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Change your wires and see if that's the remedy to your problem. </TD></TR></TABLE>
Old Jul 19, 2004 | 07:32 PM
length's Avatar
Default Re: engine won't turn over help (hondaZvic)
alright, i'll check wires tomorrow. what is the procedure to aligning a dizzy correctly.
Isn't it brink crank to top dead center, align cam with markings on it and then just stick it on the cam? let me know if there is any other trick or if that could possably be a problem with ingition?
kaiba
Sep 8, 2005 03:25 PM
rdawg000
Jan 11, 2005 11:57 AM
Geiro94rs
Nov 11, 2004 11:01 AM
E-Rok
Jul 31, 2003 08:19 AM
jspec - integra Ls
Apr 10, 2003 11:07 PM
