engine swap problems
i just swapped a 1992 civic si in to my 1990 civic dx, and when i try to start the engine, it wont start... the motor turns but it wont catch, I checked the timing belt and its perfect, so i have no idea what else it could be... im still using the distributor from the 1990 dx engine, could this be why, please help me out, thanks
How did you do the wiring? You know the new engine requires 4 injectors and your car only has 2, right? Also, you'll need an 88-91 Si distributor if you wired for 4 injectors, if you used your intake manifold and stayed with 2 injectors, use the DX distributor.
good luck,
J
good luck,
J
classciv
Apr 2, 2006 03:30 PM
firstgenrex
Oct 6, 2003 05:47 PM
Big Bang
14
Aug 22, 2003 06:18 AM
shorty91
Jun 23, 2003 11:51 AM
