Engine Missing and I can't find it!!! f22B
Old May 3, 2008 | 04:50 PM
ronqqq's Avatar
Default Engine Missing and I can't find it!!! f22B
I have a f22B DOHC in an 94 lx accord...
The engine has a bad miss..
I can pull the #1 and #4 plug wires and the engine continues to run (rough)/ no change.. I can pull the #2 and #3 and the engine will die... Telling me that the # 1 and #4 are my problem areas...
I have replaced:
Plugs
Plug wires
Dis cap
All fuel injectors
Cylinder compression is about 180 on all cyl..
Timing belt is aligned correct. Number one cyl aligned TDC with the number one plug.
I might note that while having the timing light in the#1 plug wire it seams to only fire every few times never consistent, fires correct on #2 #3.
What am I missing??
Have any ideas?
Thanks Ron
Modified by ronqqq at 6:04 PM 5/3/2008
Old May 3, 2008 | 05:44 PM
randomnineh2b's Avatar
ur distributor its self
Old May 3, 2008 | 05:51 PM
ronqqq's Avatar
Default Re: (randomnineh2b)
OK so what might I replace?
Strange that it only seams to be firing only on #2 and #3.
Old May 3, 2008 | 07:50 PM
mltv's Avatar
Default Re: (ronqqq)
I had a very similar problem like yours, but mine is H22A4
I was missing cyclinder 1 and 2 3 and 4 were running great. it turn out to be the egr valve, I had the plugs bad try pulling the vacuum on that.
Old May 3, 2008 | 07:52 PM
ronqqq's Avatar
Default Re: (mltv)
I will try it
Thanks!!
Any More info??
Old May 16, 2011 | 06:37 PM
stopsayingJDM's Avatar
what do you mean by it being your EGR valve... was it just bad? or stuck open? stuck closed?....
i took a perfectly good running f22b out of my wives car(did an h22a swap)... then put into a 95 accord that had no motor to sell.... the problem i ran into is it idles like ****... the timing is sporadic... and if you pull cylinder #1 nothing happens.... its almost like #1 and #2 are firing at the same time.... ive changed the distributor the coil, plugs, wires...still nothing.... any ideas?
Old May 16, 2011 | 06:39 PM
EmminoDaGreat's Avatar
Default Re: Engine Missing and I can't find it!!! f22B
Did you clean the egr ports?
Old May 17, 2011 | 06:17 AM
2fast4u831's Avatar
I'm really 2slow
possibly bad injectors on cyl. #2 and #3
vtec_breh
Feb 27, 2011 06:30 PM
ddeem1
Sep 13, 2010 04:06 PM
ronqqq
May 4, 2008 01:12 PM
austinkli
23
Feb 7, 2008 12:57 PM
Ur 2 Slow 4 J
Feb 23, 2005 12:28 AM
