Engine code 16...injector test/swap
My 5 min trip to the store was extended when my 89 civic LS swap wouldn't restart. It showed a #16 code...one extended bling and 6 quick ones which I read and hope is one or multiple bad injectors.
http://tech.hybridgarage.com/tech/codes.html
Is it possible to test each one to see which is bad?
Can I use an injector from an 89' crx Si as a temporary solution if it is just an injector?
