EM1 vs Integra Shift Linkage
Old Jan 14, 2014 | 05:41 AM
schneedrache's Avatar
Default EM1 vs Integra Shift Linkage
So, swapping a B into my EK. The sticky'd guide says that the EM1 linkage works better then the integra.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
"Shift Linkage: For 96-00 EK the chassis, I highly recommend to use a 99-00 Si or JDM EK4/9 shift linkage. I recently found out 94-01 integra shift linkage will not center the shift lever in the center of the shift boot area. Shifting to 2nd/4th gears the shift lever sits too far back hitting the inner edge of the shift boot console border."
Question is..
How can I tell the difference between the two? Is there a measurement of length that can be taken and can anyone provide the two measurements?
Old Jan 14, 2014 | 06:02 AM
kyden's Avatar
Default Re: EM1 vs Integra Shift Linkage
i have an integra shift linkage on mine. i never noticed that happening.
Old Jan 21, 2014 | 09:44 PM
Graham Dunbar's Avatar
Im wondering the same thing, i think a short shifter would solve this problem. also apparently its better to use the rear "t" bracket from an em1 vs an integra bracet.
Old Jan 22, 2014 | 08:14 AM
kyden's Avatar
T bracket on the engine/transmission? It's not "better", it's the only one that works.
Old Jan 22, 2014 | 09:17 PM
So an integra bracket will not work at all? will be doing an ls/vtec swap (itr head/b18a1 block. s80 tranny) into an ej6? sorry to thread jack
efhatch1991
Jun 29, 2013 10:41 AM
kornerk12
Mar 15, 2007 05:26 PM
likenother
Apr 18, 2006 07:31 PM
LSVTEC96HB
Apr 26, 2004 12:37 PM
