EKK1 or EKK2 Mounting Kit
Old Sep 1, 2005 | 04:19 PM
HondaHead211's Avatar
Default EKK1 or EKK2 Mounting Kit
I am dropping a K20 into a EK hatch or coupe and was wondering which mounting kit from hasport i should go with. i know you need a EG sub frame with the EKK2 but what sub frame do you use with the EKK1. Which would you guys recommend?
Old Sep 1, 2005 | 04:23 PM
redEH2's Avatar
Default Re: EKK1 or EKK2 Mounting Kit (HondaHead211)
you can use it of any EG subframe would work . If you dont have power steering dont buy the one with power steering.
Old Sep 1, 2005 | 07:16 PM
Default Re: EKK1 or EKK2 Mounting Kit (purpleEJ6)
what sub frame do i use with the EKK1 kit?
Old Sep 1, 2005 | 07:41 PM
itrsleeper's Avatar
check out this forum http://www.k20a.org
they have tons of info on k20/ek swaps
Old Sep 1, 2005 | 07:59 PM
redEH2's Avatar
i think you need one of a EG hatch with no power steering.
Old Sep 2, 2005 | 11:24 AM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHead211 &raquo;</TD></TR><TR><TD CLASS="quote">what sub frame do i use with the EKK1 kit?</TD></TR></TABLE>
You use the stock one in your EK.
EKK1 Kit = Stock Rear 96-00 Civic Cross Member
Old Sep 2, 2005 | 09:33 PM
brian g's Avatar
The EKK1 kit is made to be used with the car as is. You do not use a different subframe.
The EKK2 kit was designed for people who wished to have more ground clearance and the engine moved back for better balance. With the EKK2 kit I suggest using either an EG manual rack and subframe or a DC2 power rack and subframe. You can use an EG subframe and rack too, but either way get the EG or DC lower control arms too.
brian g
Old Sep 3, 2005 | 11:50 AM
Default Re: EKK1 or EKK2 Mounting Kit (brian g)
how much difference in ground clearance and balance is there between the two mounting kits
Old Sep 9, 2005 | 08:51 PM
brian g's Avatar
A little over half an inch of extra ground clearance, but the big advantage is the oil pan is much closer to the wheels. So if you draw a line from the low point on the front edge of the frame tangent to the front wheels the oil pan sits way above that. By the time a tall speed bump gets close to your oil pan the wheels are starting to drive up the bump. Same with pulling into a driveway with a steep entrance, the frame under the radiator makes contact before the oilpan can.
As for balance, I haven't done the math, but moving the 305 lb engine and transmission rearward 2 inches is significant.
brian g
Modified by brian g at 3:28 PM 9/10/2005
Old Sep 13, 2005 | 03:08 PM
ps2wayne's Avatar
With the ekk2 can you still run a turbo setup?
Old Sep 13, 2005 | 08:39 PM
98 Spec R's Avatar
Default Re: (ps2wayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ps2wayne &raquo;</TD></TR><TR><TD CLASS="quote">With the ekk2 can you still run a turbo setup?</TD></TR></TABLE>
There is plenty of room.
Old Dec 8, 2005 | 05:03 PM
x916's Avatar
Default Re: (98 Spec R)
has any run into any similiar problesm like me or am i just doing it wrong
i have a 1996 civic..have the ekk2 mount kit..eg crossmember, rack and pinion and lca..NO ps..im trying to mount my billet into the left hand bracket, but it wont let me mount it on the top holes on the bracket...it seems to be hitting it..
pics
the billet part that is hitting the bracket is indicated in red..the bracket spot its hitting is indicated in pink
Old Jan 24, 2018 | 08:28 PM
ekb16a's Avatar
brian g
hi brian now i got a question lets. Say i buy ekk1 kit from hansport but. Later on i want to go with ekk2 do i just buy rear mount lmk ppz thanks
Old Jan 25, 2018 | 07:37 AM
Hasport's Avatar
this isnt brian but ill answer your question
you would just need the EKK2 brackets to convert the EKK1 kit into the EKK2
Old Jul 21, 2020 | 03:37 PM
blkcivicsedan's Avatar
I have ekk1 and about to put del Sol subframe in so I will need the ekk2 brackets, how can I order them. I haven’t received a response from Hasport yet
Old Jul 22, 2020 | 07:40 AM
Hasport's Avatar
email me at sales@hasport.com and i can get you taken care of
43!
May 8, 2016 09:08 AM
ESP.net
Mar 24, 2008 12:43 PM
garyc17
11
Sep 1, 2006 10:21 AM
wekillyou
Oct 9, 2004 09:35 PM
