EF mounts on a 92 INTEGRA?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola »</TD></TR><TR><TD CLASS="quote">I have Ef B series motor mounts. Will they work on a 92 integra LS? Will the axles work?</TD></TR></TABLE>
I'm not sure what you are trying to do here, elaborate a little more on what you are doing: Which swap (???) into which year chassis (92 Integra?) would help.
EF B Series motor mounts meaning??? Aftermarket B series EF mount kit? or JDM Civic/CRX SiR factory mounts?
Again which axles???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola »</TD></TR><TR><TD CLASS="quote">I have Ef B series motor mounts. Will they work on a 92 integra LS? </TD></TR></TABLE>
Simple answer.... no. First off, the position is different on the transmission & rear, and the driver side mount is not wide enough and will "flop" around in the DA chassis bracket. Never did it, but if you look at it, common sense will tell you that.
pouponu
Jan 31, 2008 08:38 PM
