ecu question
Can I use the ecu from my '93 civic ex when swapping a b18c with b16a head into my car, or will I need an OBD-II ecu. I know that I will need OBD-II wiring harness and distributor, etc., but I was wondering about the ecu.
yes you can use it if you convert the harness from OBDII to OBD1 if the engine is from OBD2. Your car will run like crap but will run.
I would suggest if you want to run OBD1 then get the P28 chipped.
MaxxdoutSRT4_EK9
Jun 26, 2005 10:23 PM
