ecu question?
Old Feb 28, 2005 | 06:14 PM
smiths54aub's Avatar
Default ecu question?
i have a swapped civic cx . it has b18c1 with a p 28 ecu. v tech dosent hit until 6k and it dosent have a rev limiter. would i be better off with a stock gsr ecu and why did someone use this p 28 . whut car does it come in factory?i dunno jus feel like v tech should be hittin earlier the guy i bought it from said that ecu makes it faster
help thanx
Old Feb 28, 2005 | 07:56 PM
VTECVillain's Avatar
Default Re: ecu question? (smiths54aub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smiths54aub &raquo;</TD></TR><TR><TD CLASS="quote">the guy i bought it from said that ecu makes it faster</TD></TR></TABLE>
Most people will tell you that to sell you on something. The P28 is the stock ECU for the 92-95 Civic Si and EX. Most people reprogam them to custom specs for DOHC VTEC applications, probably your case due to the lack of a rev limiter and higher VTEC engagement. If the motor is stock as in cams and intake manifold you would be much better off with a stock 94-95 GSR P72 ECU.
Old Mar 1, 2005 | 07:19 AM
Falcon7's Avatar
Default Re: ecu question? (VTECVillain)
Yeah either that or have someone program you a new chip for the P28 that will run your motor. However you may want to look into a few different options for activating the butterflies in the intake manifold ( RPM switch, etc...) I guess it depends on how much money you have to spend cause OBD1 GSR P72 ECUs are pretty expensive in comparison to chipped P28's. I can burn you a stock program for cheap if that's the route you want to take....
Old Mar 1, 2005 | 03:51 PM
thanx
Old Mar 1, 2005 | 04:43 PM
if i go with the p72 will it be plug and play or will i have to do some wiring such as knock sensor , etc.?
Old Mar 1, 2005 | 06:03 PM
Turbogixxer's Avatar
Default Re: ecu question? (Falcon7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falcon7 &raquo;</TD></TR><TR><TD CLASS="quote"> However you may want to look into a few different options for activating the butterflies in the intake manifold ( RPM switch, etc...)</TD></TR></TABLE>
You can add IAB control to a P28. Search on http://www.pgmfi.org (Library) to found out have to do it. It will cost you like $2 in parts. My tuning P28 has IAB control.
Old Mar 2, 2005 | 03:30 AM
Default Re: ecu question? (turbogixxer)
ive got a skunk 2 manifold so i dont have the dual runners to consider , but i will check out the website uve given me thanx guys
Old Mar 2, 2005 | 01:12 PM
Falcon7's Avatar
Yes I know you can add IAB to a P28 I've been a member at PGMFI for about 3 years... Adding IAB to a P28 also requires more than just $2 in parts you need a considerable amount of experience working with electronics and a good quality set of tools (temp controlled soldering iron, etc.).. You also need a new chip burned that contains the code to activate the IABs........
Since not everyone has these sorts of things I was offering a more common alternative...
anyways.. that's all...
Old Mar 2, 2005 | 04:43 PM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falcon7 &raquo;</TD></TR><TR><TD CLASS="quote">Yes I know you can add IAB to a P28 I've been a member at PGMFI for about 3 years... Adding IAB to a P28 also requires more than just $2 in parts you need a considerable amount of experience working with electronics and a good quality set of tools (temp controlled soldering iron, etc.).. You also need a new chip burned that contains the code to activate the IABs........
anyways.. that's all... </TD></TR></TABLE>
No need for setting up the iabs since he's running the skunk2 IM. Basically, in your case, keep your p28 but run a different program...something thats more appropriate for the mods you have done, whatever that may be.
Old Mar 2, 2005 | 08:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falcon7 &raquo;</TD></TR><TR><TD CLASS="quote">Yes I know you can add IAB to a P28 I've been a member at PGMFI for about 3 years... Adding IAB to a P28 also requires more than just $2 in parts you need a considerable amount of experience working with electronics and a good quality set of tools (temp controlled soldering iron, etc.).. </TD></TR></TABLE>
I understand, there is always more options. The more people know about them, the better decision they can make.
Old Mar 3, 2005 | 05:40 PM
so is the p72 plug and play? since the project wuz sterted with p28 will i have to pull wires to make it wurk? thanxs in advance.
Old Mar 3, 2005 | 05:59 PM
iH8RICERZ's Avatar
depends what year p72 you have. Since your currently running th ep28 (i'm assuming), that means your car is a 92-95 civic/integra right? If thats the case, you'll need a obd 1 p72 or a p61 GSR ecu (i have one for sale right now ). Basically any obd 1 ecu will plug directly into any 92-95 civic/integra. obd2 (either version) will not plug into an obd 1 stock harness. There are conversion harnesses where you can run obd2A-1/obd2B-1, obd0-1, obd 1-2. You'll want to stay obd 1 either way in the end because of tuning purposes. with all this said, stick with the chipped p28 becuase your running a skunk2 intake manifold, meaning no iabs on the gsr motor anymore...that means you probably wouldnt want to run a p72
Old Mar 4, 2005 | 12:40 PM
evilk's Avatar
people use p28 because it hasno knock sensor and the p28 is from 92 civic ex
Old Mar 7, 2005 | 08:21 PM
Default Re: ecu question? (evilk)
so if i plug in a p72 i wold have to pull wire for the knock sensor right?
lovindavtec
Jul 11, 2012 09:38 AM
the.hamburglar
Dec 27, 2005 07:24 PM
jerzeytib
Oct 17, 2003 12:27 PM
bearboy80
20
Sep 17, 2003 02:20 PM
