ecu/injector help
Old Nov 3, 2002 | 08:41 PM
skud_dusty's Avatar
Default ecu/injector help
im buying a 90 civic si that has a 95 jspec sohc vtec in it. it had a turbo on it, and the guy took his injectors and ecu. he had mitsu 450 injectors in it, and a zdyne ecu. which ecu and injectors will i need to buy? he said the stock 88-91 si injectors and ecu, then just run a vtec controller, but i'd rather have the ecu control vtec instead of an vafc or something similar...
any help/opinions/options?
thanks
Old Nov 3, 2002 | 10:43 PM
poison's Avatar
Default Re: ecu/injector help (skud_dusty)
I would suggest getting the D16Z6 fuel injectors, and for the ECU, getting a P28.
Old Nov 3, 2002 | 10:51 PM
tinkerbell's Avatar
thanks
so, does it still have the turbo?
if no, poison has the right idea...
t..
Old Nov 4, 2002 | 11:41 AM
skud_dusty's Avatar
Default Re: ecu/injector help (tinkerbell)
no turbo...just the motor now. im using the 88-91 injectors because thats the intake manny it has.
i think i'll be using the stock si ecu also and just wiring a vtec controller unless we can get pinouts of the obd0 b16 ecu. thanks guys
Old Nov 4, 2002 | 06:10 PM
skunkwhat's Avatar
Just a heads up, the reason you need the 88-91 injectors is because that is what the car is wired up for. The 92-95 injectors have different plugs, but also one injector is peak/hold type and the other is a saturated type. The intake manifold does no matter, and you can also source your injectors from 90-91 integras since the d and b series both use 240 cc injectors. I can get you the vtec pinouts for the b16 ecu also
[Modified by skunkwhat, 3:11 AM 11/5/2002]
Old Nov 4, 2002 | 07:04 PM
skud_dusty's Avatar
Default Re: ecu/injector help (skunkwhat)
if i pulled the clips from the new injectors that i got, should i be able to wire them up to my wiring harness easily? i think they are the 92-95's...it says "IPT" on one side of it, and on the other side it has the numbers 4108... heres a pic of the pins:
please tell me if this is obd1 or obd 0
the kid that is helping me already has the pinouts for the b16 ecu. thank you though.
[Modified by skud_dusty, 4:10 AM 11/5/2002]
Old Nov 4, 2002 | 11:40 PM
Jaker's Avatar
Those are OBD1!
Old Nov 5, 2002 | 05:20 PM
turbo panda's Avatar
Default Re: ecu/injector help (Jaker)
would he be able to use 86-89 integra injectors? they seem to be the same as the rest, and are obd 0
any thoughts?
Matthewhughes
29
Aug 5, 2014 03:18 PM
mattm868
Aug 18, 2007 06:31 PM
X arkangel x
Apr 17, 2003 12:00 PM
