Ecu codes help
Old Jan 7, 2004 | 04:22 PM
tylek17's Avatar
Default Ecu codes help
Can some one give me list of codes for the JDM p13 ecu or USDM i think they are the same. Thanks
Old Jan 7, 2004 | 06:11 PM
Mikey3000's Avatar
Default Re: Ecu codes help (tylek17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tylek17 &raquo;</TD></TR><TR><TD CLASS="quote">Can some one give me list of codes for the JDM p13 ecu or USDM i think they are the same. Thanks </TD></TR></TABLE>
you want the whole fuggin list? do a search on yahoo or on here. i guarantee you'll find it.
Old Jan 7, 2004 | 07:03 PM
VTECVillain's Avatar
HONDA/ACURA ECU CODES
1 O2 - primary oxygen sensor
2 O2 - secondary oxygen sensor
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead center sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Old Jan 7, 2004 | 09:24 PM
tylek17's Avatar
thank you very much
JeDiMaster
10
Oct 15, 2010 06:00 PM
J4k3
16
Jun 22, 2006 08:25 AM
StraightCivic
10
Apr 5, 2006 12:27 PM
Audi A4
Apr 21, 2004 08:45 AM
BLuDoHcReX
Apr 3, 2003 07:36 PM
