ECU code 5 (map sensor) HELP
Old Apr 20, 2004 | 07:12 PM
sakums20's Avatar
Default ECU code 5 (map sensor) HELP
(95 obd1 h22 in a 2000 civic si) i got code 5, (map sensor mechanical), it boggles when i start it (no CEL) and after 1-2 minutes CEL comes on. my map sensor is hooked up, any hints/ help?
Old Apr 20, 2004 | 10:59 PM
Maintenance's Avatar
Default Re: ECU code 5 (map sensor) HELP (sakums20)
check the wirings. See if the wires are securely connected. And maybe it could be a bad map sensor. Try switching it out with another map sensor. Also check your vacuum hose from the map to the intake manifold. make sure its secure also.
Old Apr 21, 2004 | 08:05 PM
sakums20's Avatar
Default Re: ECU code 5 (racerxfear)
thanx, all good now. (vacuum lines)
Old Apr 29, 2004 | 02:40 PM
Dc_Ek's Avatar
I'm having the same problem but the only difference is that my MAP sensor doesn't use vacuum lines, I exchanged sensors with my Integra and it doesn't shows any signs of improvement!
Please help!
snidbits
Feb 11, 2011 03:19 PM
turboed rhd
Mar 17, 2010 08:47 PM
jay-d-em
Sep 7, 2006 05:07 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
